Author Topic: How to set ground clearance in eagle?  (Read 1512 times)
Offline electrowhiz
  • Country: in
« on: June 27, 2018, 03:59:23 pm »
I have finished my PCB design and then I gave it to one of the manufacturer. He told to change the ground clearance from 0.1mm to 0.3mm. How should I do it?
Offline Karel
Re: How to set ground clearance in eagle?
« Reply #1 on: June 27, 2018, 04:17:54 pm »
In Eagle you set the clearances in DRC -> Clearance.
In case you are talking about a groundplane, open the Info dialog and set Polygon -> Isolate.
For more info type: help polygon
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
The following users thanked this post: electrowhiz
Offline JustMeHere
« Reply #2 on: October 03, 2018, 11:24:51 am »
Ask them if they have a design rules file.  It can help get things going.
Online westfw
« Reply #3 on: November 02, 2018, 04:00:00 pm »
Put your ground signal in a different signal class ("Change Class"), and then use the "class" command to specify the clearance for that class...
The following users thanked this post: oPossum
