Author Topic: Library with all footprints  (Read 2001 times)
Offline glatocha
« on: June 30, 2013, 05:20:15 pm »
do you know, is there any library with just IC standard footprints?
I am making a lot of own components cause it is easy and fast. But each time I need to search through another libraries to find same package. Would be really easy to have library with just a standard footprints. Then you can simply copy to your library what you need.
Offline kizzap
Re: Library with all footprints
« Reply #1 on: June 30, 2013, 11:21:56 pm »
I generally just find the manufacturers footprint and hack together something with it...
-kizzap
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #2 on: July 04, 2013, 08:34:22 am »
The are two with the standart libs package, called ref-packages and ref-packages-longpad, lots to choose from.
Offline dumle29
« Reply #3 on: July 24, 2013, 08:54:48 am »
I like to make the footprints myself, and found that the people making datasheets like to make you work for your measurements, so I made this excel sheet.
It only does dip, and smd chips with pins on two sides (so no TQFP).
Might be of use :)
http://www.mediafire.com/view/mfybz6kic79bc2e/package_calculator.xlsx
