Author Topic: soldiring mask layer  (Read 2939 times)
Offline Ahmed
« on: October 28, 2013, 10:29:55 am »
hello everyone :)
im using eagle to create PCB , what i understand that the soldering mask layer covering everything but pads no , so how generate it in eagle ?
Offline ddavidebor
    • Fermium LABS website
« Reply #1 on: October 28, 2013, 10:40:19 am »
It's alredy there
Davide Bortolami,
Fermium LABS srl
Offline Ahmed
Re: soldiring mask layer
« Reply #2 on: October 28, 2013, 10:51:21 am »
ya how ? , what name of the layer ?
Offline kizzap
« Reply #3 on: October 28, 2013, 10:54:51 am »
tstop and bstop are the solder mask layers, however they are negatives, so they will show what isn't going to be covered by soldermask
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline Ahmed
« Reply #4 on: October 28, 2013, 11:07:39 am »
ya , for printing it i need all board black and just pads white ... can eagle do this step ?
Offline george graves
« Reply #5 on: October 28, 2013, 12:21:28 pm »
I'd look for a ULP(?) script  - I bet someone has already written one.  If not, you could "print" the layer to a PDF (there are lots of PDF "printer drivers" that let you print to a PDF) and then use a vector art work program to inverse the colors.
Online MarkL
« Reply #6 on: October 28, 2013, 10:20:08 pm »
Create a CAM job with just tStop or bStop selected, depending if you want the top or bottom, and choose the PS_INVERTED output device.
Offline Ahmed
« Reply #7 on: October 29, 2013, 08:43:39 am »
and how can print the out file on paper
Online MarkL
« Reply #8 on: October 29, 2013, 10:08:36 am »
On Linux you can use evince to view and print postscript files, or convert it to PDF with ps2pdf, and view/print with Acrobat reader.  Ghostview/ghostscript will also work, but the user interface is not as nice.
If you're on windows, I have no idea, but I'm sure there are a number of postscript viewers available that you can print from.  Do a search, or maybe someone else can step in here who knows windows.
Shouldn't be too hard, since many printers and print drivers understand postscript natively.
Offline kizzap
« Reply #9 on: October 29, 2013, 03:25:22 pm »
Easiest way as stated is to export the Cam job with the layer inverted, then open the file with a gerber viewer and print it that way.
-kizzap
