Author Topic: polygon hatch at 45 degrees  (Read 2299 times)
Offline igeorge
« on: November 18, 2013, 09:17:25 pm »
Eagle make the hatching just at 90 degrees
It is a way to make it at 45 ?
Thanks
Offline kizzap
Re: polygon hatch at 45 degrees
« Reply #1 on: November 19, 2013, 02:27:26 pm »
Short answer, No.
Long answer, finish your board, rotate the entire thing 45 degrees then redo the polygon pour, export the gerbers, then rotate the board back to 0 degrees.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
