Author Topic: Route trace where I want it - with no airwire.  (Read 1380 times)
Offline FeralCl
« on: April 13, 2018, 02:53:34 am »
I'm laying out heavy power and grounds on a PCB with several connectors each with VCC and GND.
All the connectors currently have at least one VCC and GND trace. The final trace is VCC between two adjacent connectors but there is no airwire.
Running "ratsnest ! *" followed by "ratsnest VCC" reveals airwires between VCC,  pullups, bypasses and connectors making the layout electrically correct but not what I want.
I could temporarily move components and run ratsnest until an airwire appears where I want it but there must be a better way.
Can anyone suggest a better approach?
(eagle 7.7.0 premium)
Ken
« Last Edit: April 13, 2018, 02:55:05 am by FeralCl »
Offline Karel
Re: Route trace where I want it - with no airwire.
« Reply #1 on: April 13, 2018, 03:40:58 am »
Activate the "route" command.
Keep the Ctrl-key pressed.
Left-click on a trace or pin/pad.
Release the Ctrl-key.
Layout the new trace.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
The following users thanked this post: ebastler
Offline ebastler
« Reply #2 on: April 13, 2018, 05:32:03 am »
Thanks, Karel! I had not been aware of that one.
But you forgot the "Let me know if there's anything else I can do for you."  ;)
Offline FeralCl
« Reply #3 on: April 13, 2018, 08:06:15 am »
Well that seems to work pretty well, and the now redundant airwires disappear too.
On a Mac it's the command key not control.
Thanks very much Karel.
