Author Topic: SamacSys EAGLE add-on  (Read 597 times)
Offline spec
  • MALE
« on: December 05, 2018, 05:20:37 am »
Just installed SamacSys parts search add-on for EAGLE.
There is a bit of flaffing around registering etc, but I was pleasantly surprised when it instantly found the component, I had been trying to find without luck. I just chose an existing library, clicked 'add', and the part was available right away. I must say, I was impressed. :)
Not only can you add the component to a library, but SamacSys also displays a whole load of information about the component, including a link to the component datasheet.
https://www.autodesk.com/products/eagle/blog/now-available-new-free-eagle-library-plugin-samacsys/
http://www.samacsys.com/eagle-library/
« Last Edit: December 05, 2018, 05:25:41 am by spec »
