Author Topic: Show Tool: Zoom to selection  (Read 1023 times)
Online Pack34
« on: October 18, 2016, 02:07:20 AM »
When you are not on the same schematic page as a component you will get a SHOW dialog. Selecting the component in this dialog moves you to the appropriate schematic page and zooms in on the component.
When on the same schematic page this behavior does not happen. Is there a way to force it?
The work around is to either go to a different page or zoom all the way out to see which component is highlighted.
Online Pack34
Re: Show Tool: Zoom to selection
« Reply #1 on: October 18, 2016, 03:08:28 AM »
It looks like it's the FIND tool (ctrl+f) that has the behavior I want, not the SHOW tool.
Offline jgarc063
« Reply #2 on: October 18, 2016, 05:12:17 AM »
Hi Pack,
If hope you're doing well. If you are using V6 or newer try the following:
SHOW @ RefDes
Then hit enter, replace RefDes with whatever part you are looking for.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Autodesk Support
