Author Topic: tht disk caps  (Read 1427 times)
Offline whoKnows
tht disk caps
« on: March 27, 2018, 01:23:02 am »
where can tht ceramic disk caps be found i only find this smd rubbish when going ceramic and the only tht caps i see else are elcetrolytic
Online ahbushnell
Re: tht disk caps
« Reply #1 on: March 27, 2018, 01:30:24 am »
Digikey look for throughhole caps ceramic
Sent from my SM-G930V using Tapatalk
Online ebastler
Re: tht disk caps
« Reply #2 on: March 27, 2018, 02:44:47 am »
RCL library,
e.g. C-EU025-025X050,  C025-025X050 (2.54mm lead spacing),
C-EU050-030X075, C050-030X075  (5.08mm lead spacing).
Is that what you are after?
Offline whoKnows
Re: tht disk caps
« Reply #3 on: March 27, 2018, 05:24:24 am »
i see the ones in the rcl lib and there is a 3d view for them and no it seems to be some blue rectangle thing i search these small beige disk caps
Online ebastler
Re: tht disk caps
« Reply #4 on: March 27, 2018, 05:52:31 am »
But the footprint is the same, isn't it?
I have never used the 3D view, I'm afraid. (Does Eagle 7.x even have one? I have never looked for it...)
Do you really need the 3D view? For drawing schematics and having PCBs manufactured, it is not required, and it does not matter at all if the parts look different in the 3D view than the ones yo will populate later. Unless you have very special needs (e.g. modellng something in detail in 3D, because you want to fit it ino a tight three-dimensional enclosure) I would just ignore the details of the 3D view.
