Author Topic: TL072 dual op amp in Eagle with power connections?  (Read 8064 times)
Offline stryker
« on: June 15, 2013, 05:40:14 pm »
Hi
I've found the DIP8 TL072 dual op amp in two libraries for Eagle so far, and neither has connections in the schematic for pins 4 & 8, for VCC- & VCC+.  Has anyone found one, or an alternative that's pin-compatible you can recommend that does have them?
Thanks
Geoff
Offline TerminalJack505
Re: TL072 dual op amp in Eagle with power connections?
« Reply #1 on: June 15, 2013, 06:47:23 pm »
The power pins will be there.  Right click on the symbol and click "Invoke."  The power pins will be in the list of the dialog that pops up.
Offline stryker
« Reply #2 on: June 15, 2013, 09:18:12 pm »
Thanks. I knew there had to be a secret handshake ;-)
