Author Topic: Help! Can't Open mysterious .sch and .pcb files  (Read 1017 times)
Offline guitarjoe91
« on: January 05, 2018, 05:34:19 am »
I'm struggling to open some old .sch and .pcb files from out PCBA supplier in Altium17 or Altium18.  Our supplier says the files were probably created in Protel 99.  No combination of opening the files or importers in Altium have worked thus far.  What should I do?
Online AndersJ
Re: Help! Can't Open mysterious .sch and .pcb files
« Reply #1 on: January 05, 2018, 06:11:01 am »
PADS from Mentor Graphics uses those file extensions.
sch: Schematics
pcb: Layout
"It should work"
R.N.Naidoo
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #2 on: January 05, 2018, 06:14:03 am »
Can you open the files with a text editor and post the header? (or upload files to have someone else take a look at these mysterious files).
He’s like a trained ape. Without the training.
Offline guitarjoe91
« Reply #3 on: January 05, 2018, 10:04:31 am »
Here is the header of one of the files when opened in Notepad.  Looks like a garbled mess to me:
 þ
   7                            L     L  ðŒv              !  !  Hv             A   A   h»R              À     0   X›v        0      Ø   °  `[w            d     hcw              ‘   ˜
   ew              þ  ø   ÍS              X  U   8  w “'   X
  D   P  }w    @         z  z  P“v                     (îw    @      ˜F  û   ˜F  0õw        H    ”  $   @S  Ð;x    @   P  @     $   ØÏx       $   À          @ž(                      Òx    @      À           (              C     (Ùx          $      $   @¸b       $   Field
Drawn By Field
Checked By Field
QC By Field
Released By Field
Drawn Date Field
Checked Date Field
QC Date Field
Release Date Field
« Reply #4 on: January 05, 2018, 10:19:09 am »
Yep, sch and pcb file extensions go way back to Protel days.
Earlier versions of Altium will import and open them.
Avid Rabid Hobbyist
Offline Chris56000
« Reply #5 on: January 12, 2018, 07:01:51 am »
Hi!
Have you tried using the AutoTrax Altium Freeware to open them?
NB! Please do NOT confuse this with AutoTraxDEX (Kov's) software - this is NOT the one you need!
Another possibility is they might be P-Cad 2004 files - I don't know wether trial versions are still available as P-Cad was retired years ago!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: January 16, 2018, 10:14:30 am »
Almost every PCB package uses .pcb and .sch extensions, so unless there are clues in text in the file,it's trial & error on importers/viewers
Day Job: Mostly LEDs
Offline apurvdate
  • Country: in
« Reply #7 on: January 16, 2018, 04:24:32 pm »
There is also ExpressPCB (https://www.expresspcb.com/)
I havn't used it for ages..used it in college days actually... but it has .sch & .pcb file extensions..
I see they've updated version.. classic version also available..
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #8 on: January 16, 2018, 06:26:33 pm »
Open the file in a hex viewer, look at the magic bytes.
https://en.wikipedia.org/wiki/List_of_file_signatures
Offline Nusa
« Reply #9 on: January 16, 2018, 09:42:29 pm »
Valid idea, bad source of data for this problem. There are no pcb or sch software packages on that list, not even the mainstream ones.
