I got that email this morning, dude.
Not good!
Might as well update.............I've temporarily (I hope!) gone back to Eagle for the moment until 3 or 4 issues are fixed......well, I call them issues anyways. I am hopeful though that Iliya will fix these.
- Copper pours cannot be used a full-on ground planes (despite fact you can assign a net name), result is that netwires still exist after you drop a via from say pin 4 of an op-amp to pick up GND.
- No full manual tracking per Eagle, i.e. you can't lay down a track and then assign/terminate it to a net later. You have to start with a net. This reduces the flexibility when compared to Eagle. You can lay down polylines which achieves the same thing, however, their are outwith the DRC and don't get a net name.
- UI is slow when tracking.
- Block moving stuff needs work. Not everything moves, some traces get left behind.
Here's a board I developed from scratch in both Eagle (left) and DEX (right). The DEX one pictured is at the point I gave up and went back to Eagle when I couldn't get DEX to do what I wanted without mucking about forever or compromising too much.
Saying that, I still think DEX is a winner if the various issue scan be resolved. The best bit about the software is the library management & the schematic design module.......real nice.
PS. Iliya is working on some of the issues above.
Ian.
