Hi I have not layout a board in a while,
Given a four layer board (inner: power ground) using smd components, can the connections to the inner layer be made directly or must a thermal pad/relief be used.
Using a via with a angular ring of 20mil and hole of 10 mils, what expansion value is recommend for a thermal relief?
If two thermal relief intersect, resulting in 2 out of 4 spokes connecting to the plane, does this pose a manufacturing issue.
thanks
