Author Topic: Printed Inductor design  (Read 2928 times)
Offline jtronixTopic starter
« on: August 13, 2017, 07:17:07 am »
I'm looking for printed inductor design software. can anyone help ??
Offline Gribo
Re: Printed Inductor design
« Reply #1 on: August 17, 2017, 08:56:06 pm »
Saturn PCB can get you started.
I am available for freelance work.
Offline ahbushnell
« Reply #2 on: August 17, 2017, 10:38:50 pm »
There are cores that are designed to work with windings that are in the PCboard.  For instance Ferroxcube has "Planar E cores".  The core goes through a hole in the board and windings are traces.  This is one.
http://www.ferroxcube.com/FerroxcubeCorporateReception/datasheet/E14_3.5_5_R_PLT14_5_1.5_S.pdf
They also have other types with half of the windings on the board.
Andy
Offline BigBoss
« Reply #3 on: August 18, 2017, 02:05:30 am »
Cadence Allegro with RF Option will definitely help you but it costs..
Second option is to use a 2D and cheap/free CAD program then import the sketch into PCB program as DXF format but it's a bit troublesome.
Offline rs20
« Reply #4 on: August 18, 2017, 04:48:36 am »
OP, can you confirm whether you just want software for generating gerbers for a printed inductor; or do you indeed want to actually electromagnetic simulation/analysis of said design?
« Reply #5 on: August 18, 2017, 06:28:49 am »
I want tool where i can get the design by just putting inductor value.
Offline chhrisedwards
« Reply #6 on: October 03, 2017, 10:30:34 am »
There are different types of inductors designed for various system applications. I am referring a link to you as below, may this will helpful.
http://www.electronicecircuits.com/electronic-software/inductor-design-software
Thanks.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: October 03, 2017, 10:51:00 am »
Just how many inductors are you making, that you need a one-click solution?
You must have a generous budget to pay for it, then.
Seven Transistor Labs, LLC
