Author Topic: Prototyping with SMD  (Read 5308 times)
Offline raptor1956Topic starter
« on: July 20, 2017, 12:19:37 am »
Most of the prototype work I've done in the past involved DIP packages with pins that fit standard perf board, but I have a project I'm looking at that would require SMD components and I'm wondering what the best options are for doing prototype work using SMD.  What kind of proto boards should I be looking at?
Brian
Offline amitchell
Re: Prototyping with SMD
« Reply #1 on: July 20, 2017, 12:37:31 am »
You can get smd to dip adapter PCB's.
https://www.digikey.ca/products/en/prototyping-products/adapter-breakout-boards/643
otherwise oshpark is relatively inexpensive for proto PCB's.
« Reply #2 on: July 20, 2017, 12:56:43 am »
Great, that's exactly what I was looking for.
Brian
Online ataradov
    • Personal site
« Reply #3 on: July 20, 2017, 01:00:48 am »
And all those things are 10x cheaper on eBay, as usual.
Alex
Offline KL27x
« Reply #4 on: July 20, 2017, 01:03:02 am »
Also, it is never a bad idea to have some regular proto or veroboard, extra long pin header, a sharp hobby knife, a roll of 30AWG kynar wire... and a microscope.
« Reply #5 on: July 20, 2017, 01:29:42 am »
Yep. have all those things...
Brian
Offline KL27x
« Reply #6 on: July 20, 2017, 04:50:31 am »
I'm getting ready to wire up a project. God knows why I only ordered this part in SSOP. You can tell I started at pin 24 and worked my way around, clockwise. Not the neatest effort, but it works.
« Last Edit: July 20, 2017, 04:52:49 am by KL27x »
Offline nanofrog
« Reply #7 on: July 20, 2017, 05:10:31 am »
FWIW, there are also adapter boards for passives as well as low pin count active components (i.e. SOP23). For the former, the typical double sided PTH prototype boards work with 0805 however (example), thus reducing your prototyping supplies a bit.  ;) Not expensive either, so an additional bonus.
Perhaps not a microscope, but magnification will likely help you depending on your eyesight. Steady hands too, but both are dependent on the individual (aka YMMV  :P).
Offline timothyaag
« Reply #8 on: July 20, 2017, 05:41:19 pm »
I just got some of these tqfp->dip and tsop->dip adapters: https://www.amazon.com/gp/product/B00O9YXTLU/ref=oh_aui_detailpage_o00_s03?ie=UTF8&psc=1 a couple of days ago. Just got the ICs that go with them today so I'll be trying them out tonight.
I will also vouch for OSHPark for small boards. I think I paid $10-$12/3 boards on my last two runs with them. I can't say how good of a deal they are once you get up in size and start using their extra features.
Offline whalphen
« Reply #9 on: July 20, 2017, 07:15:57 pm »
Impressive work on soldering all those wires to an SSOP chip!  I can never seem to get even a few to go where I want them.
Offline NivagSwerdna
« Reply #10 on: July 20, 2017, 07:41:31 pm »
FWIW... with my limited experience...
I bought a prototype board with a variety of footprints and a couple of other specific boards for even smaller footprints.
It works for tinkering but I think it is best to get to your own PCB ASAP as it's a PITA.
Offline zeqing
« Reply #11 on: August 04, 2017, 11:04:52 am »
would be time-cost to solder the smd IC manually, many small vendors for prototyping in China, they would be glad to help you on prototyping and thus to get your big orders.. ;D more cost-effective for 20$ than taking half a day soldering and debugging..
Offline KL27x
« Reply #12 on: August 05, 2017, 11:47:39 am »
Sure. Just buy every single prototyping board you might ever possibly need. And store them somehow you can magically find them whenever you need. And when you get low on inventory of 28 pin QFP adaptor, be sure to order more so you are never waiting on shipping.  I'm sure you have plenty of time to do all this while organizing and handling all the other bits and pieces you are using. >:D
Cry once. Buy a microscope. All of these problems go away. :)
Offline nanofrog
« Reply #13 on: August 05, 2017, 12:54:14 pm »
Funnily enough, I bought one back in February and it's still in the box.  :o The reason being I've no place to put it ATM until I completely rearrange my lab (moving the bench & adding a couple more).  |O
As per keeping all sorts of adapter boards, the OP might want to look into the dead bug method for IC's instead. It does require good soldering skills, a steady hand, and in the case of SMD packages, proper magnification (at least an OptiVisor).
Offline b_force
    • One World Concepts
« Reply #14 on: August 05, 2017, 01:10:00 pm »
Or just simply make your own adapter boards.
Nowadays you can get 10 board for 5 bucks shipped.
IF you be a little creative, you can fit 20 or more designs in those 10 boards.
Offline alank2
« Reply #15 on: August 05, 2017, 03:20:39 pm »
While they aren't always so cheap, they do have it all:
http://www.proto-advantage.com/store/
Offline chrisbrown
« Reply #16 on: August 05, 2017, 03:57:54 pm »
There have been a bunch of people asking about this recently.
I'm working on a new type of breadboard to make SMD prototyping much easier. It has a ground plane, power rails, multifunction connector footprints, adapters for SMD ICs, and an aluminum enclosure.
I'll link to the kickstarter when it launches in a couple weeks.
Offline nanofrog
« Reply #17 on: August 06, 2017, 04:15:31 am »
This could prove useful.   :)
