Author Topic: Reference Designators for Components in BOM but Not Mounted on PCB  (Read 2498 times)
Offline MixedSignalSystemsTopic starter
    • Mixed Signal Systems
In my schematics, I like to add components that are not necessarily mounted on the PCB to ensure that they are captured in the Bill of Materials (BOM) output by my CAD tool.
These might include the PCB itself, an enclosure, screws, standoffs, light pipes, cables, etc.
It's useful to capture all these in a BOM that is well controlled so that kits are built up correctly and nothing is overlooked.
I am wondering if there are standard Reference Designators that people use for these items.
Right now, I use:
PCB for a PCB :)
ENC for an Enclosure
MP for a Mechanical Part, e.g. a screw or standoff
Are there any standard alternatives that people use for these?
Any suggestions on a Reference Designator for a Light Pipe. MP doesn't seem quite right but it does do the trick.
Also, any suggestions on a Reference Designator for a cable, e.g. USB cable.
Happy to hear any suggestions that people might have.
Thanks,
Kieran
Offline Mattylad
Re: Reference Designators for Components in BOM but Not Mounted on PCB
« Reply #1 on: January 28, 2018, 12:30:05 am »
Whatever you call them, putting them on the main sheets gets confusing to the reader.
What I used to do was make a seperate sheet for non schematic BOM only parts.
This way I could also output the BOM for the whole assembly by including this sheet when printing or not.
Matty
CID+
Offline Omgitskillah
  • Country: ke
« Reply #2 on: January 28, 2018, 04:28:00 am »
Hi Mattylad,
I don't think what you are doing is conventional at al. The PCBA BOM is only for components that get mounted on the PCB. After you receive the PCBAs from the manufacturer, you may the PCBA itself as an individual component and list it in an general product assembly BOM.
That's how most people I have worked with do it.
I hope that helps.
Cheers
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: January 28, 2018, 04:53:07 am »
I normally do that, with a note (in the Comment or Description field) about where it goes, if applicable.  (The PCB item is pretty obvious where it belongs in the assembly, of course.)
Seven Transistor Labs, LLC
Offline Mattylad
« Reply #4 on: January 31, 2018, 10:37:52 pm »
Omgitskillah, I was referring to things like screws, mica washers, heatsinks et all - the stuff used on a PCB that is not shown on the circuit.
If you add things like this onto the schematic then it just looks a mess, if you do not add them then when you output a BOM it is short of these things and you need to manually add them to your final BOM.
When I first did this (on the main schematic sheet) I had QA coming up saying "ere whats these things on the drawing?" lol
However, if you use a separate sheet (one that is generally not printed) then you can add the additional items without them obscuring the schematic itself.
I know of many companies that have taken this up and used it very well - being able to print the whole PCB assembly BOM by opening the schematic.
The PCB itself becomes a part within the libraries and also gets called up in the BOM when this is added to the schematic.
This way - the whole BOM is in line with the schematic and any changes made to it, i does not have to be "just" the schematic BOM, it can be the "product" bom especially if you have no other way of managing it (I.e. no MRP system).
Yes it's not conventional, this is because convention is to generally use a seperate spreadsheet for the BOM, this is generally not in sync with the actual schematic and errors and mistakes happen often. Using the method I have mentioned keeps the whole assembly in sync.
Matty
CID+
« Last Edit: January 31, 2018, 10:40:39 pm by Mattylad »
Matty
CID+
« Reply #5 on: February 01, 2018, 02:36:13 am »
Matty
CID+
Hi Matty,
I also use this approach and find that it works quite well for most designs that I work on.
I know of a number of semiconductor companies that also use this approach for their evaluation boards, etc.
For considerably more complex products like a smartphone (multiple PCBs, etc.), an alternative approach may be more appropriate but including everything on the PCB schematic works very well for most designs that I encounter.
Usually, but not exclusively, I place all the additional components on a separate sheet at the end of the schematic.
I add a MOUNTING_STYLE attribute to all the parts in my part libraries to allow readers of the BOM to clearly identify whether or not a component is physically mounted on the PCB.
Sent from my SM-G920F using Tapatalk
The following users thanked this post: Mattylad
