Apologies if the topic title is confusing, but I'm not sure what exactly the proper terminology is.
Is there any standard way of drawing signals that are routed out of a bus in a circuit schematic? For example in the picture I attached, PortB 0 to 4 on my uC are routed to a bus. I've seen some schematics where the signals meet the bus at right angles, but others where it meets the bus at 45 deg. And in the latter case I haven't been able to find out if there's any convention to which way the 45 deg tilt should go.
