Author Topic: Take a look at my newly improved PCB viewer / Gerber Viewer  (Read 34418 times)
Offline PCB.Wiz
Re: Take a look at my newly improved PCB viewer / Gerber Viewer
« Reply #75 on: August 26, 2016, 06:19:33 am »
Maybe easier is to add a column to the BOM file? There should be a number of universal fields in the component description in any CAD package....
Yes, I agree a BOM extension is useful, but BOMs can get complex, and they are not always PCB-Centric.
Some are controlled from the SCH side, and others are run by SpreadSheet/DataBase managers... so getting the information into the BOM, can involve many steps and turf arguments....
My suggestion was not meant to displace BOM, just to give a very simple means to 'sneak' Height info into standard Gerber Files.
It is not as 'clever' as full mapping, but it is simple to implement for the user, and I think does not need too much software inside a viewer ?
I'll check other PCB sw for Gerber precision support. KiCad looks very good here, with 6 decimals in mm.
Addit:
KiCad defaults to this useful 1 um precision.
%FSLAX46Y46*%
G04 Gerber Fmt 4.6, Leading zero omitted, Abs format (unit mm)*
Mentor's PADS has some strange historic limit of 8 digits in Gerber, plus it internally stores to only 5 decimal digits-mm, so it can only give
%FSLAX35Y35*%
ie 3.5, which is still enough to export PCBs of 999.99mm to 99.9mm of suffix-height precision, using the 3.5 format.
I would propose that mm units be the default for suffix-height.
%MOMM*%
« Last Edit: August 26, 2016, 07:36:08 am by PCB.Wiz »
Offline zofz
    • 3D Gerber Viewer
« Reply #76 on: August 27, 2016, 06:11:08 am »
Addit:
%FSLAX46Y46*%
%FSLAX35Y35*%
%MOMM*%
Yes, the solution is technically possible. But I believe this feature will be rarely used, especially after the final solution is implemented. The height is not the only problem. See attached picture, also with capacitors. I need to solve the components dimensions and shapes input, in more universal way.
Take example of outline drawing - quite simple rules, but often there is a problem - there are many concepts, e.g. draw it on mechanical or on keep-out.
The structure of my setup file (.camset) is xml. I am already storing there some component settings. So if designer wants to play with different parameters, the simple way would be: Text-edit for start - more automatic and graphical edit later.
I still need to gain some experience with different BOM files.
It would be great to gain access to some repository of 3D models, without a need of loading each component by hand. I could index models my own way (by footprint fitness) so it is not much work to get a proper view..., so I need to learn STEP.
Offline zofz
    • 3D Gerber Viewer
« Reply #77 on: February 28, 2017, 01:41:03 am »
Right-click menu for component model and parameters (like elcap height) - I am still working on it. I hope to release this in couple of weeks.
Offline S13
« Reply #78 on: March 25, 2017, 11:31:22 pm »
Very impressed with this Gerber Viewer!  :-+
Thumbs up from me, and i will certainly give it a try  :)
Offline zofz
    • 3D Gerber Viewer
« Reply #79 on: August 05, 2017, 10:17:03 am »
I have published a test version featuring component shape adjustments. The settings are stored in .camset and .zofzproj files.
short youtube video:
download: https://www.zofzpcb.com/Gerber-Viewer-Download.html look for "Current Build, Pre-Alpha".
After installation, enable the "ParamTables" option in Components / Models License menu.
« Last Edit: August 07, 2017, 06:12:41 am by zofz »
Offline calli
  • 3D Blender and Maker
    • Blender Buch
« Reply #80 on: December 09, 2017, 10:19:54 am »
I was looking for a 3D Gerber View and found this.
I am quite new to this all, using Easy EDA and the Gerbers from them will let your viewer error on
%FSLAX24Y24*%
or
G90*
Am *I* doing something wrong or is it the Gerber file?
Best,
Carsten
Carsten Wartmann: Autor - Dozent - 3D - Grafik - Maker
http://blenderbuch.de/
Offline zofz
    • 3D Gerber Viewer
« Reply #81 on: December 09, 2017, 10:45:09 am »
%FSLAX24Y24*%
or
G90*
Best,
Carsten
This are OK. can you send me your gerbers? let me see this - bug@zofzpcb.com
Offline zofz
    • 3D Gerber Viewer
« Reply #82 on: December 11, 2017, 12:33:09 am »
%FSLAX24Y24*%
or
G90*
Best,
Carsten
Hi Carsten,
thanks for the Gerbers - I found the problem.
It is an extra space between '*' and '%FSLAX24Y24*%' just after the star in the previous line. Some time ago I have removed all spaces in pre-processing, what was just a hot fix. That was not the greatest move, since spaces are actually allowed, but only in the comments (like G04). Now, I have it done 'the right way' - just accepting stray spaces, but, as it shows, not in all conditions.
I have fixed this already, I will publish the hot-fix version shortly (just looking to solve one more bug).
If you like to test it before the release, just remove the space from all your gerbers, last header comment line, after the star.
Offline calli
    • Blender Buch
« Reply #83 on: December 11, 2017, 08:29:09 pm »
Thanks!
Works now perfect with Easy EDA Gerbers.
Carsten
Offline xtlc
  • Country: at
« Reply #84 on: January 29, 2019, 11:59:40 pm »
Hello zofz
I looked at your project and I sometimes follow this blog, so I thought I maybe can ask here: I sometimes put parts on pcbs, that are not in your database - for example I use many spring contacts and so on - usually I only have STP files for 3d data. Is there any way I can import them into the ZofzPCB 3D Gerber Viewer?
Offline zofz
    • 3D Gerber Viewer
« Reply #85 on: January 30, 2019, 08:17:25 am »
Hello Xtlc,
I have the documentation for STEP ap242 and I am working on a whole PCB + components export. It is simpler then component import, so it makes sense to start from this side. And I have already promised the export. About the import - what is a pitty, the step ap214/203 does not provide higher level information, e.g. about contacts. With my own library, I can do automatic fit and (later) provide footprint/component fit information (DFM). In the meanwhile, I am adding couple more of components, this time in a very universal parametric form - see pictures.
The following users thanked this post: oPossum
Offline xtlc
  • Country: at
« Reply #86 on: February 05, 2019, 12:27:47 am »
Thanks for your reply.
Can I suggest to have a ZIF connector? Maybe for starters just length, height, width and pins to adjust manually?
Offline zofz
    • 3D Gerber Viewer
« Reply #87 on: February 06, 2019, 06:17:02 am »
ZIF connector is a quite reasonable choice, you mean the tape connector, of course. And the SMD barrel power, as I already have the body.  Probably in the next cycle, as I am finishing the update right now.
Offline xtlc
  • Country: at
« Reply #88 on: February 08, 2019, 05:29:00 am »
I am thinking about a variety of these:
Also I'd love to see them in here (as they are only defined by their WxHxD and number of pins and rows of pins. Working height and so on is just an extra not really important for the mechanics, as you can alter it by altering the H(eight) of the part:
Offline zofz
    • 3D Gerber Viewer
« Reply #89 on: February 10, 2019, 09:06:26 am »
 :-+ Spring contacts - OK, I can build it out of existing primitives (vertical cylinders).
Offline zofz
    • 3D Gerber Viewer
« Reply #90 on: February 10, 2019, 10:05:41 am »
I have fixed a .zofzproj file bug and going with the flow, I have added encryption and LZMA compression to the file format. The file is a binary, private, annotated mesh. - a single file containing the whole project.
I did it, because I want to pass the component generator allowance (license) to the whoever like to open this file, in a view only mode.
Scenarios:
  • PCB designer sends his project to a client, client does not need to have a license to see the components.
  • Show a PCB based product on the Internet, without publishing the production files.
  • Something like PDF, in a sense that browser can open the link in a similar fashion.
In the "View Only" mode, "Files" menu will be removed, Stackup will be read-only, etc. I am thinking about making it hard to produce the physical PCB, out of the view file. I am continuing with the following options:
  • Allow Orthogonal FOV
  • Allow Screenshot
  • Allow Netlist Names Display/Browse
  • Allow Component Names Display/Browse
Is there anything else, you would like me to add or block, in the View-Only mode?
BTW, the zofzproj file size have changed from 32M to 5.5M, for the demo1 PCB, making it more convenient for email or download.
What do you think about the idea?
