Electronics => General PCB/EDA/CAD Discussions => Topic started by: zofz on September 06, 2015, 10:45:57 pm
Title: Take a look at my newly improved PCB viewer / Gerber Viewer
Post by: zofz on September 06, 2015, 10:45:57 pm
(http://www.zofzpcb.com/img/ScreenShot26.png)
(http://www.zofzpcb.com/img/ScreenShot23.png)
Adding IPC356 bare board flying probe test file, enables design browsing and components display. At the moment, there is no component library. Instead I am guessing using geometry of pads and components designator names from IPC356 testpoints. There is also a cross-check interface to OrCad schematic, see youtube video:
2 screen crosscheck (https://youtu.be/EROzlTwBv-M)
Free download zofzpcb.com (http://www.zofzpcb.com/)
Title: Re: Take a look at my newly improved PCB viewer / Gerber Viewer
Post by: CatalinaWOW on September 06, 2015, 11:03:02 pm
Interesting.  I hadn't seen your program before.  For others equally ignorant, here is a link.
http://www.zofzpcb.com/ (http://www.zofzpcb.com/)
Post by: timofonic on September 07, 2015, 12:25:24 pm
Your software looks interesting, but your EULA (http://www.zofzpcb.com/EULA.html) scares me to shit pure steel bricks.
Why are you so restrictive on freeware? I don't get it!
What about FOSS and Linux support?
Post by: AlfBaz on September 07, 2015, 12:30:36 pm
If memory serves, there's a thread on here somewhere where Free_Electron and the OP exchanged ideas to improve it a year or so ago
Judging from those images, it looks like it has come a long way since then :-+
Post by: codeboy2k on September 07, 2015, 06:14:26 pm
At first glance it looks great! good job!
The EULA is not that bad, it's freeware and you can basically do anything you want with it except sell it, decompile it, or otherwise try to figure out how it works.   Other than those restrictions, it's not that bad for a EULA.
It's not FOSS.
I am running it on Linux, and it runs OK under Wine.  So far no major problems, and I've tried many features.  The application says it uses DirectX 9 and  Wine emulates/translates DirectX calls so it runs fast and is quite usable  There is some font issues that make the text of the menus difficult to read. I've never had font issues under Wine before, so I attribute this to the home-brew menu system this application is using.
I would love to see the cross-probing interface opened up, so that someone can plug it into KiCad.
Good job @zofz !
Post by: BravoV on September 07, 2015, 06:21:55 pm
Great stuff , thank you !   :clap:
+1  :-+
Post by: codeboy2k on September 07, 2015, 08:33:07 pm
And if the cross-probing interface is opened up, I'd like to see it done over TCP/IP, even for a local connection.  This means that the app can run in Wine and still communicate to KiCad which will be running in Linux.    If it's a Windows DLL or some other proprietary windows message passing interface then it's not going to work cross platform or under emulations...
Using TCP for cross probing also opens up interesting other possibilities. For example, cross probing could also be be done between two gerber viewers on different hosts, not just between the gerbers and schematic capture.   Then you and a coworker can look at gerbers together for a collaboration. Or you and your board house...
Post by: zofz on September 07, 2015, 09:40:59 pm
Thanks,
TCP or UDP interface, crossprobe and navigation - i mean exact the same camera position and rotation,  that is what i am thinking of.  To form something like shared desktop.
Later, to overcome "corporate firewalls", it shoukd be using http and third server, maybe.
At the moment there are two: WM_COPYDATA and file based. I will put them to the webpage.
Post by: alexanderbrevig on September 07, 2015, 10:13:10 pm
Wow! Really cool stuff :) What lib are you using for 3d rendering?
Post by: zofz on September 08, 2015, 04:22:51 am
The library: I needed to compress the layer vertex data, it is only 2D + Z[n] as constant. That somehow forced me to do direct shader programming. But there is a DXUT as a starting point.
Post by: zofz on September 08, 2015, 04:24:29 am
The current cross-check interfaces description: WM_COPYDATA and file, can be downloaded at http://www.zofzpcb.com/Cross-Check.html (http://www.zofzpcb.com/Cross-Check.html)
Post by: zapta on September 08, 2015, 05:32:33 am
Windows only. Oh, well...
Post by: timofonic on September 08, 2015, 07:12:28 am
Thanks,
Your software seems very interesting, really.
Can you explain your reason to make a freeware with that kind of restrictive license? Or do you plan to eventually make it commercial?
If you plan to keep it freeware? Why that EULA? Why not making it Open Source?
Despite your software seems really very interesting with many nice feature, I'm afraid of propietary software these days for different reasons. Some of them are: Vendor lock-in, expensive cost, security, unable to modify or port it to other platforms...
Post by: zofz on September 08, 2015, 08:04:50 am
Thanks,
yes, This is a question I ask myself too. The most important is: how can I continue to provide this software free of charge, and realize many ideas I have? vendor lock: I will not close any feature I have already opened. I might include some new features for a commerce, however. I may also convert zofzpcb to truly free software.  I do not know. I am letting to know, anyone who bothers to read, about any internet communication, in the help file, and I can expose the sources to some trusted authority, if required. What I have at the moment is a http query for a current version, a single text file loaded, containing the version number. zofzpcb.com/version/info.txt (http://zofzpcb.com/version/info.txt) . I run your default browser, to display the help page. actions defined in the help menu. I have bought a certificate, so I am traceable and the program is protected against third party modifications on the download way. At the moment of crash, there is a possibility to automatically send a crash log/info/etc. all you can examine before sending, or chose not to send. (any way I need gerbers in case of debugging, so I need a email contact anyway). I was concerned that such question will be asked, but it was asked much later then I expected. hmm. anyway, the program is clean, the website uses google analytic. That is all.
Post by: codeboy2k on September 08, 2015, 03:54:16 pm
Excellent! Thanks for your quick response to the suggestion too. I think the file based interface can work between Windows app on Linux and a native Linux app like KiCad
Post by: zofz on September 08, 2015, 04:09:50 pm
Anyway, i   am willing to create the tcp interface. And maybe Kicad have already something done about this. There also is a idea to make adobe pdf plugin, many cad systems create schematics with rich annotations. Then click able pdf.
Sent from my SM-T800 using Tapatalk
Post by: Mechatrommer on September 11, 2015, 02:50:19 am
bug report...
1) color preset not saved correctly. when i set all layers colors and save, next time i changed color preset and set back to my theme, color changed to what i did not pick. the only way afaik to restore desired color is by saving rendered board in a file.
2) gui issue: why dont pan with right click? universe rotate for right click is less practical imho. keep pressing shift may induce carpal tunnel on my left hand. any other sw capable of single hand navigation.
3) gui issue: mousewheel scroll zoom too slow, i cant set the zoom rate. many scroll to get desired zoom may induce carpal tunnel in my index finger.
4) sometime saving and reloading color preset generates error (see attached picture)
my platform, WinXP SP3 32bit. anyway some of the previous issues discussed sometime ago have been solved, keep up the good work. i'm learning to populate 3d component, any easy clue without using orcad?
Post by: Mechatrommer on September 11, 2015, 03:09:37 am
also how do it make the core/prepeg opaque? i dont have specific whole opaque gerber for the board, i only have board outline and zofpcb just render it as... an outline. i dont want to keep disabling and enabling the bottom (or top) layers/slikscreen/mask while rotating the pcb top to bottom and back. non opaque board messing the view with crisscrossing bottom and top traces (and copper pours) as arrowed below...
Post by: Mechatrommer on September 11, 2015, 04:33:05 am
ok got it with "auto load function". i must say this App is several magnitude better than gEDA Gerber Viewer, gerv (functionally), even without 3d components i'm currently in. except the gui and some issues i raised earlier. i believe this App must be told to the world, it deserves recognition, keep it up!... :-+
Post by: Karel on September 12, 2015, 05:25:51 pm
I'll give it a try when the open-source native Linux version has been released.
Post by: timofonic on September 13, 2015, 12:15:58 am
I'll give it a try when the open-source native Linux multiplataform version has been released.
Fixed! ;)
Post by: MagicSmoker on September 13, 2015, 03:15:50 am
Uh... I'm pretty sure the OP said it's free...  :-DD
And to the OP - impressive job!
Post by: Mechatrommer on September 13, 2015, 03:21:01 am
I'll give it a try when the open-source native Linux multiplataform multiplatform version has been released.
Fixed! ;)
Fixed! ;)... until then, let us wingows and wine people enjoy the nice app, you can continue with gEDA. ;)
Post by: timofonic on September 13, 2015, 10:27:19 am
Fixed! ;)
I don't use gEDA. I'm an Eagle user slowly transitioning to KiCad.
I don't know weird programming languages and fork my EDA tool. I barely know about programming at all.
I'm a newbie and KiCad might be more than enough, just I miss better file format interoperability and better UX.
By the time I would need something like Altium, I hope KiCad got improved a lot and even being a contributor of it in some form.
Post by: zofz on September 16, 2015, 04:57:49 pm
bug report...
Thanks,
1. color save/restore bug report is clear.
2. Possibly no one uses right-drag anyway. I would not destroy too much, if I make camera rotation on shift-right drag and use right drag for moving. I will consult a long time user for this. The other way is to make everything configurable, but that makes me feel pain.
3. OK, I will think about a nice and simple way to adjust (or dynamically auto-adjust) the zoom speed.
4. A troll must have been changing the code when I was not looking OR unknown are paths of the user.
Post by: zofz on September 16, 2015, 05:04:29 pm
The way to show components is to load IPC356 file. As Wikipedia lists, this file is possible to export by (almost) all CAD packages. Full name: bare board electrical test file (or flying probe test file). I will read it if it contains net names, and designators, so recreating this file via CAM software from Gerber makes no sense. Problems: load example 1, check the file there.
Post by: zofz on September 16, 2015, 05:15:41 pm
It looks like some aspects of my stack-layer are not intuitive. I am doing auto insert of FR4 if you set the board thickness. This is quite hidden, one must select the board outline to see the total-thickness setting (and the board outline must be there...). It is the second time I see that someone missed this. - Important! Of course Auto does it all, if it works...    Of course you have discovered the "volume" slider later.
Post by: alank2 on September 16, 2015, 10:13:50 pm
I checked out your viewer the other day zofz - it is pretty cool.  Keep up the good work!
Post by: free_electron on September 19, 2015, 01:39:18 am
just tried one of my 'monsters' ... took over 3 hours to load and crunch but  renders perfectly
Post by: nctnico on September 19, 2015, 02:25:45 am
Unfortunately it doesn't work from Windows in a Virtualbox even with directx9 installed (Why isn't that included? It doesn't make sense to distribute software without it's key components). Too bad there is no native Linux version...
Post by: timofonic on October 12, 2015, 11:00:11 pm
 I was going to try it in VirtualBox :(
Post by: timofonic on November 07, 2015, 04:43:11 am
Any news?
Post by: zofz on January 10, 2016, 01:53:20 am
A new version! :scared:
As requested:
Component individual hide and swap to bottom (for THT) options.
Right mouse button drag moves the PCB,
Additionally:
zofzproj file saves colors and layer on/off state, 10 recorded camera orientation positions,
Variable additional layer types, (not by auto-load yet)
Plus:
many bug fixes.
nothing about Linux/OSX yet |O
http://www.zofzpcb.com/Gerber-Viewer-Download.html (http://www.zofzpcb.com/Gerber-Viewer-Download.html)
Post by: timofonic on January 10, 2016, 02:25:00 am
This library might be useful for you...
https://github.com/bkaradzic/bgfx
Post by: c4757p on January 10, 2016, 03:29:49 am
Sweeeet, I'll have to give it a test.
Linux would be nice, I suppose, but it's nice enough that you put in all this effort and just give it away. ^-^ I just stick it in a VM.
Post by: rx8pilot on January 10, 2016, 04:59:08 am
I love it. Really nice addition to my layout work flow.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Post by: Jay_Diddy_B on January 10, 2016, 04:59:24 am
I have been using ZofZ for a few years now.
I would just like to say thank you. It is a great tool !!
Regards,
Jay_Diddy_B
Post by: sleemanj on January 17, 2016, 07:02:46 pm
Tried this tool, it crashed on my gerbers (using under VMWare mind you).
You can grab them here if you want to test:
http://sparks.gogo.co.nz/crashygerb.zip (http://sparks.gogo.co.nz/crashygerb.zip)
FWIW, these gerbs were created as a merge of a number of boards with a (still beta) panelizing tool.  Some other gerb viewers also have problems with them, so you are not alone.
Circuit People's tool gets it right (http://circuitpeople.com/)
KiCad's gerbview mostly gets it right (some silk funnyness).
The current git version of Geda's gerbv gets it right provided you increase the maximum arperture parameters from 102 to something larger (and recompile) (https://github.com/sleemanj/gerbv/blob/master/README.md).  These gerber's include polygons with a couple hundred parameters (100+ points), going by comments in gerbv's source it may be that there used to be a limit of 50 points in the gerber spec, but the current gerber spec I believe may have up to 5000 points.
Post by: zofz on January 19, 2016, 05:24:39 am
Thanks, a quite interesting idea. By reading the doc, I found out that I can use compiled shaders from direct3D in openGL  :)
But the biggest part of code to handle would be DXUT - and especially DXUTgui - that is a user interface framework for Direct3D. As far as I see, there is no abstraction layer for this in bgfx and I still need to find a new fitting GUI "widget" library, common for both Direct3D and OpenGL, then convert to it, first in the windows version.
Post by: kc8apf on January 19, 2016, 05:42:36 am
A lot of the 3D apps I've worked on separate the 2D UI from the 3D rendering.  The 2D UI is implemented in a per-platform fashion using the native OS widgets.  The 3D rendering is tied to a canvas placed in the 2D UI.  3D text is still an issue but that's rather unavoidable.
Post by: zofz on January 19, 2016, 05:44:21 am
OK, I can repeat the crash - thanks. In my case it seems to be related to drills. Also - need to remember - I need to implement a step and repeat and the new nested repeat commands. Might be important for panelizing. About the number of parameters - I have been already making problems to myself  and hopefully solved it. see the picture - it is a single aperture :)
Post by: zofz on January 19, 2016, 06:04:52 am
Maybe that was a wrong decision. I wanted the performance even on weak graphic cards. I have seen performance boost when using 3D only / full screen mode. (e.g. the old method - allow to reduce resolution in 3D mode.) Now this is not that important and it would be a opportunity to switch to use the OS native GUI. I have to think it over.
Post by: zofz on January 21, 2016, 09:22:51 am
The bug was related to the board outline processing. I am in the middle of other fixes, but here is a current build which can read your project.
http://www.zofzpcb.com/Download/ZofzPCBpre.exe (http://www.zofzpcb.com/Download/ZofzPCBpre.exe)
BTW, the first point of every outline loop in combined.GKO is repeated twice - this should be no real problem, however.
Post by: rx8pilot on January 21, 2016, 09:52:23 am
Just downloaded the latest, works great. Really appreciate this useful tool!
Post by: sleemanj on January 21, 2016, 10:19:11 am
 :-+ Nice one
Post by: timofonic on February 01, 2016, 05:12:06 am
Quote from: zofz on January 19, 2016, 05:24:39 AM (http://www.eevblog.com/forum/index.php?topic=53561.msg845200#msg845200)>Quote from: timofonic on January 10, 2016, 02:25:00 AM (http://www.eevblog.com/forum/index.php?topic=53561.msg838825#msg838825)
>https://github.com/bkaradzic/bgfx (https://github.com/bkaradzic/bgfx)
bgfx author is quite supportive, I'm sure he'll provide you sueful feedback about that. It's  used in a very wide variety of software (https://github.com/bkaradzic/bgfx#who-is-using-it), from CAD/CAM to videogames.
Blender and many other tools use OpenGL. What's wrong with that?
There's ImGUI (https://github.com/ocornut/imgui) that started as code for Media Molecule's Tearaway game.
ImGUI: A bloat-free graphical user interface library for C++.
  • Outputs vertex buffers to be rendered the 3D-pipeline enabled application.
  • Fast.
    • Portable.
    • Renderer agnostic.
    • No specific build process is required. You can add the .cpp files to your project or #include them from an existing file.
    • Self-contained within a few files that you can easily copy and compile into your application/engine: imgui.cpp, imgui.h, imgui_demo.cpp, imgui_draw.cpp, imgui_internal.h, imconfig.h (empty by default, user-editable), stb_rect_pack.h, stb_textedit.h, stb_truetype.h
    • No external dependencies.
    • Your code passes mouse/keyboard inputs and settings to ImGui (see example applications for more details).
  • As opposed to UI for the average end-user, it’s designed to:
    • Enable fast iteration.
    • Empower programmers to create content creation tools and visualization/debug tools.
    • It favors simplicity and productivity.
      • Toward this goal it lacks certain features normally found in more high-level libraries.
  • Particularly suited to integration in:
    • Realtime 3D applications.
    • Fullscreen applications.
    • Embedded applications.
    • Games.
    • Any applications on consoles platforms where operating system features are non-standard.
Post by: printedcircuit on February 19, 2016, 07:50:51 pm
can anyone tell me if this software
1. can measure the size of the keepout layer like cam350?
2. can automatically find and output the width of the smallest via, narrowest trace/space?
Post by: zofz on February 19, 2016, 08:08:17 pm
Hi, there is no automatic DFM/DRC check at the moment. There are:
1. manual distance measurements,
2. netlist check
I forgot about displaying the diameter by mouse hover, I did not finish it - will be done very next version.
Post by: Philfreeze on February 19, 2016, 08:41:25 pm
I am impressed, this looks gorgeous and it is free. Well done OP.  :-+
(http://replygif.net/i/1082.gif)
Post by: Rutger on March 02, 2016, 06:53:53 am
Nice job, I like it, it worked with some Altium generated gerber files.  :-+ :-+ :-+
Post by: Iwanushka on April 27, 2016, 06:45:17 am
zofz,
Very impressive work you have done, this project saved my life (well at least countless hours trying to trace the board and check/compare footprints, component orientation, etc), was working on a project that was made by a very good programmer, but as we know most programmers assume that you "know all", and in the end I had somewhat broken bom, pdf with schematics and gerbers with poor silkscreen with no outlines for component orientation.
It would be very nice if you will have free time and of course if it's possible to link Altium generated schematic PDFs to gerber viewer, so you can click on part in pdf and it shows on which two pads you need to solder the part when you have 6x6 matrix of identical pads which has no outline to show you on which two pads to put the part :)
P.S. it would be nice if you could setup some donation system (maybe paypal), so the guys and gals can support your work, as we know these things consume lots of time and you need to pay your bills...
Best Regards,
Mantas.
Post by: vzoole on April 28, 2016, 12:52:02 am
It is a really impressive software.
And non of pricey tools have similar nice 3D capability (except Zuken CR-8000 for 100000$).
But I'm in trouble with long name files.
I couldn't recognise layers manually as you can see on the picture.
Post by: zofz on April 28, 2016, 03:30:09 am
zofz,
Best Regards,
Mantas.
Hi Mantas,
Thanks,
I have been already investigating the PDF "crosscheck". Back then, I found that I would need the expensive SDK. I am looking at it again, using Spy++, but my only Altium PDF does not show the designator and pin number in the popup window. Maybe I need a different print options, but my Altium try-out period is over. Can you provide me a better pdf, e.g. from one of the demo projects?
Post by: zofz on April 28, 2016, 03:38:42 am
It is a pity that I decided to create my own GUI instead of using windows. That was because of better performance and possibility of a different resolutions in full-screen mode, where the GDI  is disabled. I have put the issue on the buglist - I see it not for the first time. I am still not certain how much should I optimize for 3D performance. Recently there is a lot more of graphic power in the standard PC, from the other side laptops and 4K...
Somehow I will solve it - let me think.
Post by: ElektroQuark on April 28, 2016, 05:13:38 pm
Any possibility to port to Linux?
I'm in the process of migrating completely to Linux and I will really miss ZofzPCB.
Post by: zofz on April 28, 2016, 05:22:29 pm
Hi, Linux and OSX port is on the list, but it is not a priority. I know it works with Wine - a temporary solution.
Post by: Kjelt on April 28, 2016, 05:50:37 pm
Looks great zofz, will try it out soon.  :-+
Is there a possibility to generate pictures (bitmap) of the sides of the finished pcb so you can directly put them in the SMT assistant software?:
http://www.eevblog.com/forum/manufacture/smt-assistant-software-for-handplacing-parts-free-and-awesome/msg873696/#msg873696 (http://www.eevblog.com/forum/manufacture/smt-assistant-software-for-handplacing-parts-free-and-awesome/msg873696/#msg873696)
Post by: ElektroQuark on April 28, 2016, 08:35:27 pm
I will try Wine. Thank you.
Post by: Bud on April 30, 2016, 01:24:18 pm
Here is some feedback
I have the program crashed all the time during navigating through the file folders on the hard drive when selecting a design to open. Win 7 64-bit, 32Gb RAM, Nvidia 570. I had to move the design files to a short path location (i.e. E:\Temp) to be able to open them.
3D SpaceNavigator mouse works in the program. I think it would be convenient if an option added to lock the mouse rotation point. Say, I mouse click in the center of the board and then lock it. Then the view will always rotate around the board center. It is annoying that accidental mouse move/click reposition the rotation center and the board all of a sudden moves in an unexpected way.
On a same note, it would be useful to add a "Reset view" or "Center view" or "Home" button to reset the view. The board flew away from the view once and I could not figure out how to get it back unless re-render it in the load menu.
EDIT:  One more: you should allow the user to select where to install the program. For now it is hard coded to be installed in c:\program files. I install all my programs on a different drive, keeping C for the system.
Post by: zofz on August 17, 2016, 11:05:14 pm
I have not been seeing the GUI crash, finally I have corrected 2 bugs. Last one is related to moving mouse during double-click, after reloading directory list. My mouse driver was probably removing this. Big thanks to two users who shared logs and helped me in debugging.
That alone would make a new release. I have started table based component library - a step before STEP mechanical CAD output. Now you can see standard frame lead packages. After I have all primitives, the lib should be populated faster now.
Youtube: https://youtu.be/4tTQO3qRJ_I (https://youtu.be/4tTQO3qRJ_I)
Post by: PCB.Wiz on August 18, 2016, 10:07:30 am
Wow- This is very impressive.
I quickly tested with
https://github.com/FPGAwars/icezum/tree/master/src-kicad
and used Altium File names.
It looks 99.5% ok, with some minor issues / quirks / puzzles
* Long file names do not fit in the file-views, and there seems no way to resize those ?
* I see a strange effect, where Holes with no traces, show under hover, but all those with traces show no holes ?
  ( The holes that do appear and tag, look fine, so the drill file must have read ok)
  Looks almost deliberate, but unexpected ?
* when I enable IPC356, 3D nicely (magically!)  appears in most cases, but in a one (U6) some strange slight spin is seen ?
 There are some vias-as-parts (Via**) still to be cleaned in this test example, so the large area over TQFP144 is a 'false positive'
 Addit: I see U6 is an unusual 16 pin SO (2/6/2/6), so maybe the angle is just a fit-artifact of trying to align over that ?
It seems to have different pin-pitch on each of 2 chosen pin sides ? - so is trying to make sense of the less common footprint.
Post by: IanJ on August 18, 2016, 04:19:11 pm
Was looking for a standalone gerber viewer to work with Circuitstudio files......this seems to work fine.
One very small issue.......on one of my boards (still under dev) the silkscreen on the underside happens to cross directly over some THP's. From the topside looking through the holes you can see the silkscreen jumping across the pad......should really be broken by the pad/hole.
Not sure I like the non-standard looking GUI dialogues but that's a minor preference thing. All in all, one of the best gerber viewers I have tried.
Ian.
Post by: PCB.Wiz on August 19, 2016, 11:12:57 am
Another angle is to say that is correct - usually silkscreen is pulled back from pads, and some EDA have a option to avoid pads, (I think some do this by 'plot-white') so anything that does not avoid pads (& holes), is considered an issue that needs upstream fixing.
Post by: wasyoungonce on August 19, 2016, 01:00:33 pm
Many thanks zofz.  Nice program.  Noticed using Eagle it wanted the ".dri" file not the txt drill file.  Some parts not rendered properly but that's probably the IPC D 356 and eagle.  now I just have to read up the help files on how to use correctly.
Post by: zofz on August 19, 2016, 07:12:22 pm
I will download and test. I do not see the board outline on the screen shot - it might be source of problems with solder mask.
Post by: zofz on August 19, 2016, 07:19:10 pm
I could do the subtracting (silkscreen minus solder mask), as a option. But first I need to rewrite the flattening - it takes too long time for some projects, and I do not want to make it more complicated now.
Post by: zofz on August 19, 2016, 07:27:47 pm
I still need to add more components to tables, and tune up pin-pad ordering/fitting, e.g. using the above project (https://github.com/FPGAwars/icezum/tree/master/src-kicad) as a next example for testing. Also, It must be possible to overwrite the automatic guessing of components.
dri and txt is a bit of the problem because of Altium/Eagle file naming schema - I need to think about it.
Post by: wasyoungonce on August 20, 2016, 12:49:26 pm
I had a look at the IPC D 356 file on parts particularly the x,y,r sizes positions.  As you can see, a few parts were not rendered or are not right:
Capacitors rendered too low in height;
a few T092 transistors not rendered correctly, their tops are too low like the caps);
An IC wide SOIC16 not rendered at all; Inductor not rendered (looks like SIL pins);
JST XH 2.5mm pitch connector not rendered (base of board);
Another ZR 1.5mm pitch JST not rendered properly (near LQFP64);
Crystal HC49S not rendered correctly;
wire pads not rendered correctly (look like pins) (VIAs ok);
Image sensor ICX453AQ (large device) not rendered properly, should be on bottom "16" layer.
Is there a way I can fix these issue?   I have played with Eagle 3D and POV Ray and made my own parts before.  But, that might give a nice image, but it's just eye candy, it hasn't the in depth analysis and details your program has!  :-+
Don't worry about the part off the board, that's just me!
Post by: zofz on August 23, 2016, 07:05:11 pm
https://github.com/FPGAwars/icezum/tree/master/src-kicad (https://github.com/FPGAwars/icezum/tree/master/src-kicad)
Finally I had a moment to invastigate it a bit.
1. Board Outline file was assumed to be .gbr - it looks that it should be .gm1  - I have changed it by hand or should that be a rule?
2. KiCad generated plated and not plated drill files. Both files should be plated. I am not drilling thru the top/btm copper in a case of not plated holes, assuming the copper is not there. This is why the holes was not visible from top/bottom.
3. Many components are not correctly represented.
3.1 QFP table needs update - maybe the fpga have a bit different dimensions.
3.2 The non-standard QFP should be represented by pad-extruded-universal-type, it is represented by strange SO. - this clearly is my bug.
link to gerbers + config file (0.5MB)https://www.zofzpcb.com/bugpic/icezum_jul27.zip (https://www.zofzpcb.com/bugpic/icezum_jul27.zip)
link to rendered board file (2.5MB)https://www.zofzpcb.com/bugpic/icezum_jul27-rendered.7z (https://www.zofzpcb.com/bugpic/icezum_jul27-rendered.7z)
Post by: zofz on August 24, 2016, 11:12:26 am
The only information i have from ipc356 is:
pad/hole x,y, pad size x,y, net-name, component designator.
So I can combine pads to form components and get a little clue what this might be: R,L,C,Q,U,J... So obviously I have no clue what is the height of the electrolytic cap.
My first step was to display a kind of extruded pads, then adding component body to it. This is allowing to e.g. highlighting a pad or a component, or point it by the mouse and identifying it on the right panel.
In this release I have been adding a table based library, including R and C (and L) 0603, 0802.., leaded 2 row and 4 row L and J-lead packages. The tables are not complete yet. So far it is possible to distinguish J from L lead, just from the footprint size.
If the table-component does not fit nicely, the program should default to the older "extruded" representation.
I am targeting STEP output, maybe as a freemium feature. So I still need to finish the tables and add another level of detail, for mechanically rich components like connector and switches - STEP model load.
In the meanwhile, I am trying to load BOM and identify columns, map components from BOM to IPC356. Unfortunately there are very fuzzy rules about component naming and component footprint naming. The BOM file load is already implemented, but it is only used to display component info on the right panel. Not for selecting the 3D shapes.
When BOM file read is working correctly, I can use the information, maybe checking by an Internet distributor website, what are the actual capacitor sizes, ceramic and electrolytic. This information is generally not present in a CAD PCB project, I need to (re)construct it by other means, asking the user for it, in the last instance. (Now you can hide or swap THT to another side, by a right mouse click menu)
Thanks for showing me what components I need to take care of next, and showing me the bugs. I would appreciate to get Gerbers, ipc356 and BOM, if it is possible, by the nature of the project (OSH vs. commercial).
Btw, the board outline is probably not identified correctly, as I see on the picture.
Post by: wasyoungonce on August 24, 2016, 12:54:27 pm
zofz...many thanks here are the gerbers, IPC D 356  and BOM.  Zipped.
I tried some editing of the IPC file...it didn't change things I wanted.
.....Now you can hide or swap THT to another side, by a right mouse click menu...
Yes noticed this.  This helped on the image sensor ICX453AQ.  Which is a 34 pin (extra) wide DIP.  These are not common IC packages, had to make my own, so no tables will match it.  It was rendered on the top...I clicked it to the bottom.  Damn excellent feature.
Brendan :-+
Post by: PCB.Wiz on August 25, 2016, 09:28:42 am
Great - That's looking  improved :)
KiCad usually puts Board outline on layer Edge.Cuts
I applied the Altium naming, as that seemed to import better, so I guess that maps Edge.Cuts to some Gerber name.
I'm not following this exactly ?
I would expect all holes to appear in the viewer, and if there is some means to show plated/non plated that is nice.
Even just a hover-check would be ok, but a copper/fibreglass type colour render for plated/npth would be cool...
ie a hole should not be discarded or not shown in a viewer.
In the test I did,  it looked like the non-trace-connected holes did render as expected.
Post by: PCB.Wiz on August 25, 2016, 10:45:38 am
...... So obviously I have no clue what is the height of the electrolytic cap.
Tables and BOM mapping can give good results, but are of course more work.
Some simpler means to communicate height is needed.. I did see someone mention a nifty trick a while back, of using the Line width to encode the Height.
I just tried this in KiCad, and it saves and Gerber plots to 6 decimals in mm.
That allows line widths to .01 mm and gives up to 4 more digits for height, which could be (fixed point) any  of 9.999mm or 99.99mm or 999.9mm
Pick one - perhaps 99.99mm, covers reasonable heights, and anything > 100mm can always use a 3D table, and 99.99 tolerates 5 decimal digit mm gerber files as 99.9mm . (not all PCB products can plot to 6 decimals in mm)
This could give a simple user-3D-option, whereby they can just edit their library, and not need any more associations at all.
KiCad can currently create and plot footprint info to these non copper layers
PFR_Widths-F.Fab.gbr
PFR_Widths-F.SilkS.gto
PFR_Widths-F.CrtYd.gbr
PFR_Widths-B.Fab.gbr
PFR_Widths-B.SilkS.gto
PFR_Widths-B.CrtYd.gbr
Q: Is there enough info in the IPC356 and gerber files to relate outline info to a component ?  My guess is no ?
I'm wondering about the best way to extrude here...
I see Kicad can remove Silkscreen over Pads, which it does by a simple dual plot process in one file
 first Outlines at %LPD*%  (Plot Dark),
 then Pads(mask) at %LPC*% (Plot Clear) to remove any silk outline info within the pad regions
That could allow an outline on Silk layer, (safely removed over pads), but the pre-removal outline is fraction-scaled-extruded to give height.
User would nominate the Gerber file containing the (fractional encoded) height info, and the rest is simple software ?
Post by: zofz on August 25, 2016, 05:44:13 pm
There are so many options or styles. Maybe I should read the file description file for the major packages - of course the format (or rather layout) is temporary - not too stable, or, perform more testing...
Note: you are free to modify "%APPDATA%\ZofzPCB\CAM_Load_Rules.txt - If you then send it to me, it will be beneficial for the community and the next update will not overwrite your changes.
Yes, you are right - that is a bug. (Now on BugList.)
Note - the non-plated holes are there, if you look inside or strip one copper layer - they are just covered by non-drilled copper. And this have to be changed. By the way - it is possible to assign different colors to plated and to non-plated holes.
Adding metallic and FR4 reflection http://www.rastertek.com/dx11tut10.html (http://www.rastertek.com/dx11tut10.html) would be the best.
The plated/non-plated have influence on the netlist checking.
Post by: zofz on August 25, 2016, 06:07:20 pm
Maybe easier is to add a column to the BOM file? There should be a number of universal fields in the component description in any CAD package.
However, using a reference to a component distributor index gives more options. It is also beneficial to the assembly shop. Also, eg. the immediate price calculation, auto-loading of 3D models,  DFM tests...
Farnel have API for their database queries. Generally it is possible to parse any distributor web page - the information there is somehow systematic - they need to be indexed by Google, to some extend...
I have been making calculations of such index file size - it is not soo big, if a proper compression-schema (dictionary tree) is used. That is probably easier to download the whole index once per month or so, then wait for the website to answer, for each part.
Post by: PCB.Wiz on August 26, 2016, 06:19:33 am
Maybe easier is to add a column to the BOM file? There should be a number of universal fields in the component description in any CAD package....
Yes, I agree a BOM extension is useful, but BOMs can get complex, and they are not always PCB-Centric.
Some are controlled from the SCH side, and others are run by SpreadSheet/DataBase managers... so getting the information into the BOM, can involve many steps and turf arguments....
My suggestion was not meant to displace BOM, just to give a very simple means to 'sneak' Height info into standard Gerber Files.
It is not as 'clever' as full mapping, but it is simple to implement for the user, and I think does not need too much software inside a viewer ?
I'll check other PCB sw for Gerber precision support. KiCad looks very good here, with 6 decimals in mm.
Addit:
KiCad defaults to this useful 1 um precision.
%FSLAX46Y46*%
G04 Gerber Fmt 4.6, Leading zero omitted, Abs format (unit mm)*
Mentor's PADS has some strange historic limit of 8 digits in Gerber, plus it internally stores to only 5 decimal digits-mm, so it can only give
%FSLAX35Y35*%
ie 3.5, which is still enough to export PCBs of 999.99mm to 99.9mm of suffix-height precision, using the 3.5 format.
I would propose that mm units be the default for suffix-height.
%MOMM*%
Post by: zofz on August 27, 2016, 06:11:08 am
Addit:
%FSLAX46Y46*%
%FSLAX35Y35*%
%MOMM*%
Yes, the solution is technically possible. But I believe this feature will be rarely used, especially after the final solution is implemented. The height is not the only problem. See attached picture, also with capacitors. I need to solve the components dimensions and shapes input, in more universal way.
Take example of outline drawing - quite simple rules, but often there is a problem - there are many concepts, e.g. draw it on mechanical or on keep-out.
The structure of my setup file (.camset) is xml. I am already storing there some component settings. So if designer wants to play with different parameters, the simple way would be: Text-edit for start - more automatic and graphical edit later.
I still need to gain some experience with different BOM files.
It would be great to gain access to some repository of 3D models, without a need of loading each component by hand. I could index models my own way (by footprint fitness) so it is not much work to get a proper view..., so I need to learn STEP.
Post by: zofz on February 28, 2017, 01:41:03 am
Right-click menu for component model and parameters (like elcap height) - I am still working on it. I hope to release this in couple of weeks.
(https://zofzpcb.r.worldssl.net/Other/compparam.gif)
Post by: S13 on March 25, 2017, 11:31:22 pm
Very impressed with this Gerber Viewer!  :-+
Thumbs up from me, and i will certainly give it a try  :)
Post by: zofz on August 05, 2017, 10:17:03 am
I have published a test version featuring component shape adjustments. The settings are stored in .camset and .zofzproj files.
(http://cdn.zofzpcb.com/list/0006_to220.gif)
short youtube video: http://www.youtube.com/watch?v=PwlOs4IVZuA (http://www.youtube.com/watch?v=PwlOs4IVZuA)
download: https://www.zofzpcb.com/Gerber-Viewer-Download.html (https://www.zofzpcb.com/Gerber-Viewer-Download.html) look for "Current Build, Pre-Alpha".
After installation, enable the "ParamTables" option in Components / Models License menu.
Post by: calli on December 09, 2017, 10:19:54 am
I was looking for a 3D Gerber View and found this.
I am quite new to this all, using Easy EDA and the Gerbers from them will let your viewer error on
%FSLAX24Y24*%
or
G90*
Am *I* doing something wrong or is it the Gerber file?
Best,
Carsten
Post by: zofz on December 09, 2017, 10:45:09 am
%FSLAX24Y24*%
or
G90*
Best,
Carsten
This are OK. can you send me your gerbers? let me see this - bug@zofzpcb.com
Post by: zofz on December 11, 2017, 12:33:09 am
%FSLAX24Y24*%
or
G90*
Best,
Carsten
Hi Carsten,
thanks for the Gerbers - I found the problem.
It is an extra space between '*' and '%FSLAX24Y24*%' just after the star in the previous line. Some time ago I have removed all spaces in pre-processing, what was just a hot fix. That was not the greatest move, since spaces are actually allowed, but only in the comments (like G04). Now, I have it done 'the right way' - just accepting stray spaces, but, as it shows, not in all conditions.
I have fixed this already, I will publish the hot-fix version shortly (just looking to solve one more bug).
If you like to test it before the release, just remove the space from all your gerbers, last header comment line, after the star.
Post by: calli on December 11, 2017, 08:29:09 pm
Thanks!
Works now perfect with Easy EDA Gerbers.
Carsten
Post by: xtlc on January 29, 2019, 11:59:40 pm
Hello zofz
I looked at your project and I sometimes follow this blog, so I thought I maybe can ask here: I sometimes put parts on pcbs, that are not in your database - for example I use many spring contacts and so on - usually I only have STP files for 3d data. Is there any way I can import them into the ZofzPCB 3D Gerber Viewer?
Post by: zofz on January 30, 2019, 08:17:25 am
Hello Xtlc,
I have the documentation for STEP ap242 and I am working on a whole PCB + components export. It is simpler then component import, so it makes sense to start from this side. And I have already promised the export. About the import - what is a pitty, the step ap214/203 does not provide higher level information, e.g. about contacts. With my own library, I can do automatic fit and (later) provide footprint/component fit information (DFM). In the meanwhile, I am adding couple more of components, this time in a very universal parametric form - see pictures.
(http://cdn.zofzpcb.com/list/0020_ManyParams2.png)
(http://cdn.zofzpcb.com/list/0019_ManyParams.png)
(http://cdn.zofzpcb.com/list/0018_HeaderPlacement.gif)
Post by: xtlc on February 05, 2019, 12:27:47 am
Thanks for your reply.
Can I suggest to have a ZIF connector? Maybe for starters just length, height, width and pins to adjust manually?
Post by: zofz on February 06, 2019, 06:17:02 am
ZIF connector is a quite reasonable choice, you mean the tape connector, of course. And the SMD barrel power, as I already have the body.  Probably in the next cycle, as I am finishing the update right now.
Post by: xtlc on February 08, 2019, 05:29:00 am
I am thinking about a variety of these:
(http://www.elete-tech.com/upload/11/2010111420591174409.jpg)
Also I'd love to see them in here (as they are only defined by their WxHxD and number of pins and rows of pins. Working height and so on is just an extra not really important for the mechanics, as you can alter it by altering the H(eight) of the part:
(https://sc01.alicdn.com/kf/HTB1MFrnJVXXXXbdXpXXq6xXFXXXg/pogo-pin.jpg)
Post by: zofz on February 10, 2019, 09:06:26 am
 :-+ Spring contacts - OK, I can build it out of existing primitives (vertical cylinders).
Post by: zofz on February 10, 2019, 10:05:41 am
I have fixed a .zofzproj file bug and going with the flow, I have added encryption and LZMA compression to the file format. The file is a binary, private, annotated mesh. - a single file containing the whole project.
I did it, because I want to pass the component generator allowance (license) to the whoever like to open this file, in a view only mode.
Scenarios:
In the "View Only" mode, "Files" menu will be removed, Stackup will be read-only, etc. I am thinking about making it hard to produce the physical PCB, out of the view file. I am continuing with the following options:
Is there anything else, you would like me to add or block, in the View-Only mode?
BTW, the zofzproj file size have changed from 32M to 5.5M, for the demo1 PCB, making it more convenient for email or download.
What do you think about the idea?
(http://cdn.zofzpcb.com/list/0021_ViewOnly.png)
