Greetings EEVBees:
--Dave Jones once said, famously, to beginners, that "I hope your next project doesn't work". Meaning that they would have to get out the DMM and begin an investigation, reading schematics, checking continuity, testing components, verifying voltages, etc., and in the process getting an education in what being and electronic fix it guy is all about.
--The Bob Parker Blue ESR Meter by Anatek truly helps fulfill Dave's wish. The Bob Parker design is brilliant. The on board diagnostic software, full schematic, and part layout make it easy to repair. Unfortunately the Bean Counters at Anatek have induced some problems that must be causing a lot of folks to do unnecessary repairs and modifications.
--I assembled and calibrated the meter with no problems, it worked perfectly. Then I noticed that the right angle tactile switch was getting dodgy. The switch eventually gave up, so I desoldered it. The switch (see picture below) has four legs, only to of which are used in the switching action. The other two are provided (and this is a common practice for switches and jacks), to be soldered down to plated areas on the board, merely to provide mechanical stability. Whoever made the boards screwed up, because there were no plated areas for the switch support legs to solder to. Therefore the switch rocked back and forth until it destroyed itself.
--I managed to order two of the worlds cheapest (the only ones I could find) right angle tactile switchs from Uncle Lo of HK for 99 cents, shipping included. After a month I received the switches. I then installed one, and solved the rocking problem by soldering a piece of hookup wire to the legs on the back of the board. Meter was now reading abnormally. To diagnose, I shorted out a resistor as instructed and replaced the battery with an adjustable power supply to provide the specified under voltage. I then pushed the new, firm, button for 5 seconds and it gave me a diagnostic code. This hint allowed me to eventually point to a transistor. When I desoldered the transistor I noticed the trace was broken. I jumped the trace with a wire. Now the meter, would not stay on. I found another transistor with a broken trace, Huh. This problem was solved with a 1/4" of bare jumper.
--That is four problems caused by the circuit board. The two broken traces are owing, no doubt, to the fact that these are the thinnest tinned traces I have ever seen, they do not even look like copper. So while, indeed, I like the instrument, and I did not mind an hour or two of investigating, desoldering and soldering, I did not like having to wait a month for a 50 cent switch, and I hope no more of the traces will break. With it safely in the case, my fingers are crossed. I think Dave should dial back the intensity of his "wish" to a simple Platypus double whammy, and not the dreaded Tasmanian Devil quadruple whammy.
"He didn't know where he was going. But he knew where he was wasn't it."
Lord Buckley 1906 - 1960
Best Regards
Clear Ether
