For the record, I was never bother by the layering in STD periph library. Layering comes to me as AA huge advantage, as I most worked in a corporate environment where layering is a requirement for certification and documentation purposes.
I never thought the STD periph library is meant to be used without a user layer - to me it is nothing but a C representation of hardware registers. As such, it is meant to be layered, or customized, by the user in a way that suits his or her programming style.
That applies to even simpler things like port operations. Even on an 8bit mcy, I have never written a line like
PORTD |= portVal;
Instead, I have always used
IOSET(TXPORT, portVal);
With layering, I can write code that is almost entirely hardware dependent - for someone who sells code that runs on user-specified hardware, that's a must.
Taking on a new project for me many times is mostly redefining pins, or settig some macros, and linkingnin the right modules for the target, hit compile and I'm mostly there.
I charge lots of money, without ever worrying about lossing business to someone on prices, because I can deliver quality code quickly, thanks to layering.
Si layering to me is a huge competitive advantage, a huge asset. To me, if you cannot afford to layering, you are in the wrong business.
I often laugh, silently, at those fools who brag abbout writting hardware specific code to shave off 18 bytes. The more code like that you write, the more time you have to spend deciding if you should pay your rent or your cable bills,
