Author Topic: EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope  (Read 280107 times)
« Reply #75 on: November 11, 2018, 08:58:37 pm »
Is it hackable?
Yes!
(we just don't know how easy it is, yet...)
« Reply #76 on: November 11, 2018, 09:00:12 pm »
woohoo! individual channel controls!
And a single (multiplexed) cursor control knob...wah..wah..wah.
Once you have them you will never go back.
It's touch screen though. Dave never seems to get used to using his finger for menu selections but I'm sure other people will.
Offline nctnico
« Reply #77 on: November 11, 2018, 09:48:02 pm »
Above 350MHz you need active probes, etc. I imagine that's why there's a 350MHz option - you can just about use ordinary probes there.
That is nonsense. You can even build a DIY passive probe which goes to 1GHz for a few dollars worth of parts. And then there is Ebay with used probes and I'll probably be releasing a 'cheap' >1GHz differential probe soon.
The following users thanked this post: Pizzalover
« Reply #78 on: November 11, 2018, 10:21:47 pm »
I didn't say you can't. I only said you start to need active probes at about 350MHz.
...and in marketing land that implies a big price hike (the device is now "professional").
Offline nctnico
« Reply #79 on: November 11, 2018, 10:23:15 pm »
Oh and one more comment on the video... Dave... the MSO5000 has a friggin' touch screen! Use it! Don't use the select knob and buttons at the side of the screen.  :box:
OTOH it makes me wonder if the user interface has been really designed for a touch screen like the R&S RTB2000 / RTM3000 or that it is just a touch-enabled existing user interface.
Online EEVblogTopic starter
« Reply #80 on: November 11, 2018, 10:55:31 pm »
If the 2ch 70 MHz model can be hacked to a fully optioned 4ch 350 MHz with decoders then it will sell, other then that it's a dog at retail pricing.
It's competitive with competing models at the low end, but absolutely not at the higher end.
« Reply #81 on: November 11, 2018, 10:57:19 pm »
uBoot output:
U-Boot 2014.01.Rigolee.dirty (2018.06.12 - 12:12:01)
Memory: ECC disabled
DRAM:  448 MiB
NAND:  OnDie ECC supported, 1024 MiB
zynq-edac f8006000.ps7-ddrc: ecc not enabled
Has that actually got ECC memory but they disabled it?
I greatly doubt they'd use ECC memory.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #82 on: November 11, 2018, 11:13:22 pm »
Is it hackable?
Yes!   (we just don't know how easy it is, yet...)
To save people the time and trouble they should have just whacked a three way selector switch on the back with a few options.
1. Not hacked at all.
2. Hacked just a bit.
3. This thing is fully hacked.
The following users thanked this post: mrpackethead, Pizzalover
Offline nctnico
« Reply #83 on: November 11, 2018, 11:38:16 pm »
uBoot output:
DRAM:  448 MiB
No and no. Some NAND ROM memories have the ability to do the error correction on the chip itself (this has nothing to do with the DDR RAM memory). However you'd still need to take care of the bad block management in software. Most SoCs have a NAND controller which can do error detection & correction in hardware with a better software interface so it is easier to deal with. Doing the error correction entirely in software is also an option.
« Last Edit: November 11, 2018, 11:40:49 pm by nctnico »
Offline mrpackethead
  • D Size Cell
« Reply #84 on: November 12, 2018, 01:04:09 am »
Is it hackable?
Yes!
Who is best placed to do the hacking? Im sure that we could rustle up enough support to buy one to send it to the best rigol-hackery-shop we know?      I'd put in a $100 speculative to fund the entry level one, anyone else want to play?
Curious, if the 350Mhz bandwidth is just arbitoryly defined by software.
On a quest to find increasingly complicated ways to blink things
Offline TheSteve
  • Living the Dream
« Reply #85 on: November 12, 2018, 03:35:39 am »
Hah, you replied to my post twice now with the same message(more or less).
I dunno, $900 for a 70 MHz 2 ch scope still seems pretty blah to me. The fact that it needs heatsinks on the front end ASIC's is also pretty lame for a newly developed chip.
VE7FM
Offline TheSteve
  • Living the Dream
« Reply #86 on: November 12, 2018, 04:29:57 am »
The chip is capable of a few GHz. Think of the bias current required for that.
I guess it depends on how good it really is. 10 years old tech can build a front end chip good to 1.5 GHz + that has no heat sink at all.
VE7FM
Offline LapTop006
« Reply #87 on: November 12, 2018, 04:30:39 am »
1. Nah, bro.
2. It's lit.
3. Absolute unit.
Offline bitseeker
« Reply #88 on: November 12, 2018, 04:45:58 am »
Well at least 'pulses' is spelled right this time... -ducks and runs-  >:D
I noticed that too.
Yep, this time Rigol went for "Threhold" — three times on the same screen. At least it's consistent, I suppose. ;D
(Free QA, as usual. You're welcome, Rigol.  >:D)
The following users thanked this post: oPossum, HerbTarlek
Offline tautech
« Reply #89 on: November 12, 2018, 04:47:52 am »
I noticed that too.
Pluses Threhold ?  :-//
Offline bitseeker
« Reply #90 on: November 12, 2018, 04:52:12 am »
Maybe on the next model.
Online Bud
« Reply #91 on: November 12, 2018, 05:15:39 am »
Is it hackable?
Yes!
Before hacking it needs to be checked for proper PLL functioning and power supplies oscillation.
Online Bud
« Reply #92 on: November 12, 2018, 05:17:18 am »
White stuff gets really dirty really quickly. Black stuff you can't see it as bad.
Black ThinkPad here too which is really mucky but you can't see it :)
You guys do not understand, it is all about diversity. The next model will be Pink.
Or Rainbow.
Offline Brumby
« Reply #93 on: November 12, 2018, 05:23:12 am »
Nah .... Just wait.  They'll have programmable colours you can set up in software.
Offline ResistorRob
« Reply #94 on: November 12, 2018, 05:58:20 am »
His "World Exclusive" actually wasn't. Batterfly uploaded a hands-on video a couple days before he did  ;D
Dave never went back and did a review on the Siglent 1104X-e like he promised in the teardown video, so I was very happy this time he actually included a quick demonstration within the video.  As an aside I was reading the comments on this video and most are overwhelming complaints about looks and price.
I think is a great scope for the money, and love the way it looks, so don't understand all the people bashing it. The only real negative I see is I wish the screen was brighter. Like Dave said in his video it appears bright but actually isn't. In the Batterfly video you can see the screen is dimmer than what you would hope for.
For my 10th Birthday I got a Fisher Price oscilloscope!
Offline bitseeker
« Reply #95 on: November 12, 2018, 06:59:39 am »
OK, not about looks and price from the short demo? Well, the interface is laggy. It's got Rigol's famous, but different this time, spelling errors. Also, I hate the rectangular grid. The screen is wide, but instead of providing more horizontal divisions for looking at signals, they stretched them out to fill the space.
Offline ebclr
As soon as hack is confirmed
« Reply #96 on: November 12, 2018, 07:10:25 am »
I will buy one, Otherwise money will remain on bank
Offline Circlotron
« Reply #97 on: November 12, 2018, 07:40:13 am »
No hi-res mode? Show stopper for me.
Offline simone.pignatti
« Reply #98 on: November 12, 2018, 09:09:10 am »
OMG !!! Should I open one now? I will be fired lol
« Last Edit: November 12, 2018, 09:11:30 am by simone.pignatti »
Technical Support
The following users thanked this post: richfiles
« Reply #99 on: November 12, 2018, 09:18:10 am »
Show us another photo at the end of the month and we'll see how well it sells  ;D
I've heard the 7000 has been a really tough sell
