Author Topic: What did you buy today? Post your latest purchase!  (Read 2790779 times)
Anthocyanina, Gixy and 12 Guests are viewing this topic.
« Reply #125 on: June 22, 2015, 07:02:39 pm »
That was quick Robrenz......... They had the amalgam inside the springs. Took a while to get the one to move freelt, it was so full in the tip area. He rarely uses amalgam these days, as he has gone mostly to composite fillings and UV cure resin. Still has the amalgam equipment, but it is rarely used and only for some places. Next year he wants to replace my amalgam fillings, as they are aging, but still in very good condition.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #126 on: June 22, 2015, 09:00:49 pm »
As vast as your experience seems from the content of your posts you must be at least 115 years old. So I would say your amalgam fillings have served you well :-DD
Offline TerraHertz
    • It's not really a Blog
« Reply #127 on: June 23, 2015, 03:33:00 am »
You gave it away mentioning the amalgam inside one.
They could be used as miniature grease guns?
Though, an ordinary syringe and needle works as well.
Heh, he gives *you* that feeling too?
What's the use of getting older if one is never going to catch up with those guys?
« Last Edit: June 23, 2015, 03:36:53 am by TerraHertz »
« Reply #128 on: June 23, 2015, 04:34:32 am »
If I am 115 then you must be closer to 200 then..........
Close in age to Dave though.......
Offline TerraHertz
« Reply #129 on: June 24, 2015, 04:06:35 am »
One of those cheap-arse Chinese vacuum hold-down pivoting vices.
I'd never bought one before, due to my workbenches usually being wood-topped. Which are too rough and porous to hold a suction cap seal. But now my soldering desk has a mirror finish ceramic tile top, which works as well as glass with the suction cap.
Recently I looked these up on ebay-from-China, and found prices of Au$31 (free post), or Au$20+$12.50 postage. I'd intended to buy one the next time I ordered some stuff.
Yesterday I happened to be in Jaycar Bankstown, and their price for the exact same model is Au$29.95. Ha ha... I wonder what their import landed price was?
Anyway, it's one of those simple, cheap but never-quite-happened things I've wanted for most of my life.
They are cheap diecast, wouldn't do for any rough work, but are great for holding circuit boards while soldering. The jaws are steel, with V-grooves and rubber clip-on soft-jaws.
By the way, those tiles are 600mm square, hard vitreous stoneware ceramic, and come in 3-packs for about $12 a pack from Bunnings.  I happened to also have a few half width ones in a different color I'd found in a dumpster ages ago. Together they fit the table very well.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #130 on: June 24, 2015, 04:17:13 am »
Thats the Aldi vise, there is a couple of pages on it floating around the forum somewhere.
Muttley
Offline Mr.B
« Reply #131 on: June 24, 2015, 04:20:19 am »
...By the way, those tiles are 600mm square, hard vitreous stoneware ceramic, ...
I had considered doing the same when I built my workbench, however decided against it because I was concerned they might be too cold to be working on (touching).
How do you find them?
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline Deathwish
  • Country: wales
« Reply #132 on: June 24, 2015, 04:30:00 am »
those two syringes only made me think of one thing, a series of auctions in which they sold old syphilis syringes , made my skin crawl, yuk  :scared:
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline TerraHertz
« Reply #133 on: June 24, 2015, 05:02:08 am »
They are quite thermally conductive, so feel cold to the touch in cold weather. If that was a bench where I sat writing or using keyboard/mouse for long, it would be uncomfortable. But it's a workspace dedicated to soldering (and using microscopes.) So it doesn't seem to be a problem, since my hands don't rest on the bench much.
Also, the tiles are not fixed down. I could easily take them off temporarily if needed. There's a sheet of 3mm MDF underneath, to protect the table surface. The table is a sentimental heirloom - made by my grandfather.
I did have a coldness problem with a thick aluminum 'computer tray' in a rack. Using the mouse on that was quite unpleasant. But easily solved with a mousemat. When I get the cameras for microscopes sorted out, and have to use the mouse at the soldering desk a bit, I can add a mouse mat here too.
Ah, here it is: https://www.eevblog.com/forum/buysellwanted/(uk)-mini-vice-at-aldi-from-5th-feb/
Re the suction cap leaking - wipe the surface and suction cap with a damp cloth first. On a glass-smooth surface it makes a perfect seal. I test-stuck that vice down yesterday and it's still solidly attached.
« Last Edit: June 24, 2015, 05:16:27 am by TerraHertz »
Offline ElektroQuark
    • ElektroQuark
« Reply #134 on: June 24, 2015, 06:45:57 am »
Quote from: Muttley Snickers on Today at 04:17:13
Thats the Aldi vise
Or the LIDL ones.
Offline Mr.B
« Reply #135 on: June 24, 2015, 08:47:09 am »
...They are quite thermally conductive, so feel cold to the touch in cold weather. If that was a bench where I sat writing or using keyboard/mouse for long, it would be uncomfortable...
Yes, I figured they might be a bit cold... I tend to "elbow rest" in my workspace, except while soldering of course...
Thanks for your feedback TerraHertz.
Online Shock
« Reply #136 on: June 24, 2015, 11:06:26 am »
The cheap benchtop vice at Aldi are Workzone brand and jave been historically been on sale at $15 (only during Feb) until sold out. I preferred the suction cup version, and while they aren't perfect you can mount it on block of wood (for example) and put it anywhere on the table. It's also heavy enough to do smaller jobs without anchoring.
« Last Edit: June 24, 2015, 11:14:02 am by Shock »
Offline McBryce
« Reply #137 on: June 24, 2015, 11:26:44 am »
Or you can buy the exact same vice for twice the price if you choose the Proxxon labelled version: http://www.axminster.co.uk/proxxon-fms-75-precision-vice
Obviously paint in puke inducing colours costs more :)
McBryce.
« Last Edit: June 24, 2015, 12:55:23 pm by McBryce »
Offline Josephine85
« Reply #138 on: June 24, 2015, 12:36:34 pm »
reading posts in this topic :-DD
Offline kolbep
    • ShoutingElectronics.com
« Reply #139 on: June 25, 2015, 08:16:46 pm »
Just won an auction for
50Pcs ULN2003ADR ULN2003A ULN2003 TRANS 7 NPN DARL 50V 500MA
SMD.
for $3.32
I only needed about 5 of them. Now I need to figure out what to do with the rest. They are very useful little chips, especially for driving relays with a PIC micro...
www.ShoutingElectronics.com Don't just talk about Electronics, SHOUT ABOUT IT! Electronics Blog Site and Youtube Channel
Offline Circuitous
    • Corgi-Tronics
« Reply #140 on: June 26, 2015, 12:47:26 am »
I had to work some overtime, and then wait to get paid for it, but...
  this finally arrived!
A Keithley DMM7510... not a loaner, she's all mine.
Offline Mr.B
« Reply #141 on: June 26, 2015, 12:51:55 am »
I had to work some overtime...
Very nice!
I would need to do some serious overtime for that...
USD3k divided by 0.50c per hour, less tax... Hmmm... forget it.
    • ElektroQuark
« Reply #142 on: June 26, 2015, 07:48:26 am »
Where are the good quality front panels gone?
Offline Deathwish
  • Country: wales
« Reply #143 on: June 26, 2015, 07:57:35 am »
Wheres the pic of the back and all the ports
Offline Circuitous
    • Corgi-Tronics
« Reply #144 on: June 27, 2015, 12:47:30 am »
The ports, in all their glory!
  • The 2 and 4-wire jacks, 3 Amp and 10 Amp jacks
  • Along the bottom are the LAN, USB device, DB9 (digital I/O), TSP Link (dual jacks), and GPIB
  • Just to the right of the fuses is the external trigger port (DIN)
Offline Deathwish
  • Country: wales
« Reply #145 on: June 27, 2015, 01:39:05 am »
Mmmm, can't wait to see it on my workbench , yeah, I know, but a fella can dream  :-DD
Offline jhalar
« Reply #146 on: June 27, 2015, 03:29:34 am »
Bought this week:
An Agilent MSOX-3104A 1GHz fully optioned premium used oscilloscope and an Agilent U1733C LCR meter.
To replace an old Tektronix TDS220.
Electronics and Network Engineer. Working in both worlds.
Offline vk6zgo
« Reply #147 on: June 27, 2015, 05:31:14 am »
A Partridge in a pear tree----I'm starting my Christmas shopping early! ;D
Offline Deathwish
  • Country: wales
« Reply #148 on: June 27, 2015, 07:37:16 am »
I started a list, its not much, but I am nearly out of toilet roll and ink.
Offline tautech
« Reply #149 on: June 27, 2015, 09:50:31 am »
Went away for a few days and thought I'd better turn my PC off at the wall........
Flicked the switch late last night and BOOM.......  :wtf:  :rant:  :scared:
Ripped her apart as we do, and some rotten bug(6 legged type) had crawled into the PSU.  :palm:
Off to the PC parts shop for a new PSU with fingers crossed hopeing thats all that was fried.
New Coolermaster 450W PSU and we're back.  :clap:  :phew:  :popcorn:
