Author Topic: What did you buy today? Post your latest purchase!  (Read 2756061 times)
Offline GreyWoolfe
  • NW0LF
« Reply #275 on: August 04, 2015, 01:00:37 am »
That's the plan.  I am sending SWMBO on vacation next week to see her daughter in Texas, so I will have to save pennies up for awhile before I can get a wand and stand.  It would be fun to do a comparison review.
Offline nanofrog
« Reply #276 on: August 04, 2015, 02:43:28 am »
NEW replacement iron: Easybraid Shp-1 (replaces Metcal MX-RM3E; this or MX-RM3E usually run ~$100 on the street). Good deal if you can grab one before the seller runs out.
Stands: MX-WS4 (discontinued), current WS1, or Thermaltronics SHH-5 (new, either runs ~$65). Or if you've something laying around (i.e. metal coil type), you could figure out how to add a pair of magnets to enable the auto-setback/sleep feature.  :-/O I'd even see if the SHP-1/RM3E fits the Hakko 936's stand.   ;D
And then there's ye olde coffee cup...   :wtf:   >:D Hint, hint: $60 & a tip = you're off to the races (time to start a donation fund or crowd fund?).  :popcorn:
Offline GreyWoolfe
  • NW0LF
« Reply #277 on: August 04, 2015, 02:59:31 am »
I am going to have to go back to the surplus place.  They had a bunch of stands by the PSU's, but I don't know what kind.  I didn't pay attention as they didn't have any wands.  I feel my arm being twisted up behind my back to visit again. >:D
Offline nanofrog
« Reply #278 on: August 04, 2015, 03:15:12 am »
:-DD
BTW, would this be the particular surplus store on Fairbanks, right off of I-4?
Offline Mark
« Reply #279 on: August 04, 2015, 05:22:37 am »
Keysight MSOX3054A.    :D  So it's bread and water for a day or two....
Offline Deathwish
  • Country: wales
« Reply #280 on: August 04, 2015, 05:38:57 am »
Bench meter from Kev, solder from RS. They should rename this EEVbroke.forum ........  :-DD
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
« Reply #281 on: August 04, 2015, 05:46:18 am »
Bench meter from Kev, .....
Any chance it has a boot cycle counter?  ;)
Offline Deathwish
  • Country: wales
« Reply #282 on: August 04, 2015, 06:22:32 am »
Probably
Offline wxm145
  • Country: cn
  • pcbgogo pcb sample
    • Pcb Sample Quick Turn
« Reply #283 on: August 04, 2015, 07:51:24 am »
i bought a mirror yesterday :scared:
we are factory which fabricates the pcb sample quick turn fabrication.
www.pcbgogo.com
Offline pickle9000
« Reply #284 on: August 04, 2015, 07:57:53 am »
Nice, can it hang?
I got 3 baby jelly doughnuts, milk and a med slurpee.
Offline wxm145
  • Country: cn
« Reply #285 on: August 04, 2015, 08:17:13 am »
Nice, can it hang?
wow, mine could not be hanged.
www.pcbgogo.com
Offline GreyWoolfe
  • NW0LF
« Reply #286 on: August 04, 2015, 11:44:01 am »
:-DD
No, actually, this is a new store in New Smyrna Beach, the next town over from me called Planet Surplus.  Definitely reminds one of that particular store. :-DD  Doing some further checking, I found a problem with the second RF connector.  I am going to start a new thread in the repair section.  At least channel 1 works fine.
Offline WZOLL
« Reply #287 on: August 07, 2015, 02:59:39 am »
Parts for a Music From Outer Space Weird Sound Generator and a 4017 sequencer.
Offline Mr.B
« Reply #288 on: August 07, 2015, 04:06:03 am »
On its way from Franky...
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline Vgkid
« Reply #289 on: August 07, 2015, 04:40:29 am »
I have the same thermometer, also bought from Franky. I might have been one of the first to buy one.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #290 on: August 07, 2015, 06:00:58 am »
HP 8590A Spectrum Analyzer.  It's drifty, but it's cheap and works!
Tim
Seven Transistor Labs, LLC
Offline Mr.B
« Reply #291 on: August 07, 2015, 06:57:01 am »
Are you happy with it?
Is it accurate in the solder paste melt range?
Offline VK5RC
« Reply #292 on: August 07, 2015, 12:29:37 pm »
Received a ChipWhisperer Lite, I am going to have to do a lot of reading to get the best out of this puppy!
Offline retrolefty
« Reply #293 on: August 07, 2015, 02:06:05 pm »
  After waiting at least a month on backorder, finally able to order one of these. Due Saturday.
 Simply a nice general purpose bluetooth serial link. It's ability to pass on a 'reset' DTR signal (actually it's just a general purpose digital output pin under PC user's COM channel control.
 Used with an arduino type board this output pin can force a reset condition on the micro allowing the bootloader to activate for wireless 'sketch' downloads. Now your mobile robot can have it's brain reloaded wirelessly on the run.
I wonder if Windows 10 upgrade will be compatible with? Hope for the best.
https://www.adafruit.com/products/1588
Offline Vgkid
« Reply #294 on: August 07, 2015, 10:38:40 pm »
I haven't tested it for accuracy, but it seems to be pretty consistent between the two thermocouples. If you take them together they are generally less than +/-0.2 counts away from each other, generally about 0.1 count away.
I will post a quick teardown, along with the current consumption when I get home on the weekend.
Offline hendorog
« Reply #295 on: August 08, 2015, 06:23:42 am »
Not sure if this is of interest, but I got one of these 3d printers:
http://www.aliexpress.com/item/Hot-Full-Acrylic-Quality-High-Precision-Reprap-Prusa-i3-LCD-Acquired-DIY-3d-Printer-Kit-with/2026704108.html
Its actually pretty good, I had already built a 3d printer but it was a bit of a DIY nightmare to keep it running.
This one worked out of the box (took about 4 or 5 hours to put it together and will take another few hours to tidy up all of the cabling etc)
Of course as soon as I pushed the buy button I found this one which looks a little better made and is slightly cheaper. doh!
http://www.aliexpress.com/item/Black-Factory-High-Quality-Precision-Reprap-Prusa-i3-DIY-3d-Printer-kit-with-2-Rolls-Filament/32357171936.html
Offline Marc M.
« Reply #296 on: August 08, 2015, 12:10:41 pm »
HP 5371A Frequency and Time Interval Analyzer w/ two 54003A from Fleabay for $200.00 + $49.74 Shipping.  I've got some FE5680 Rb Standards, a NTBW50AA GPSTM, and (recently thanks to the forum), a Lucent RFTG-u REF0, REF1 package. When I started, it was easy - the Rb was correct  :). But then I got a second Rb and suddenly I no longer knew what time it was  :-//. So I picked up the NTBW50 to resolve the issue....  well that just made things worse |O.  Probably what I need is another GPSDO to finally clear all this up  :palm:. When the recent thread on precision timing references popped up I scored the Lucent RTFG setup for $100 (Shortly after they jumped up to $200 then a little while later they dropped it to $150.00. Glad I scored it @ $100). I finally concluded that the more precision clocks I have the less certain I am about what the correct time is.  So, now I'm hoping that purchasing the 5371a will provide the ability to finally resolve my personal dilemma of what time is it :phew:.
Special thanks to Ed Palmer for afflicting me with this nonsensical pursuit of determining when it's time to feed the cat aka Timenut  8). You Voltnuts stay the hell away from me  ;D.
Don't replace the cap, just empty the filter!
Offline Vgkid
« Reply #297 on: August 08, 2015, 02:45:01 pm »
Nice score Marc. I contemplated a 5371 a few years ago,  but something looking like an o-scope appears suspicious.
Offline AF6LJ
« Reply #298 on: August 08, 2015, 05:03:02 pm »
Indeed. very nice score.
Sue AF6LJ
Offline fivefish
« Reply #299 on: August 09, 2015, 03:25:07 am »
HP 8904A
