Author Topic: Hioki 3801 Digital Multimeter  (Read 11368 times)
Offline zaokaTopic starter
« on: January 27, 2011, 07:53:47 pm »
Very accurate, good quality Japanese multimeter.
This is older model of 3801 and is a bit slow when measuring capacitors. If selected manual range, voltage readings are pretty fast.
Switch selector has that high-quality feeling.
Display is very good and with good contrast.
Overall very good!
Re: Hioki 3801 Digital Multimeter
« Reply #1 on: January 27, 2011, 07:58:48 pm »
Looks like new Agilent meters are actually HIOKI multimeters with few changes. Maybe Hioki 3801-50 looks exactly the same as Agilent U125X.
Switch selector looks exactly the same etc...
Compare to EEVBLOG 56
« Last Edit: January 27, 2011, 08:14:35 pm by zaoka »
« Reply #2 on: January 27, 2011, 08:07:02 pm »
Looks good IMO, though clearly an older design (all SOIC/QFP with huge 50mil pin spacing, some trimmers). Most meters are fairly slow measuring caps, think about RC time (charging a C through an R), and that multimeters don't exactly represent a low-impedance voltage source (relatively large R).
Offline Kiriakos-GR
« Reply #3 on: January 28, 2011, 01:28:23 am »
The bright side of such similarities , could be that they share the same LCD,
but in this case it does not work that way.
