I generated sw4stm32 project for stm32f427 (144 pins) prototype board using STMCubeMX 4.7.0 and imported it to Eclipse, working straightaway. Absolutely it is a great tool. So far I tested SDRAM (64MB), Ethernet (RMII), USB host (MSC using two pins), USB device (VCP using two pins), SDIO (1 bit), USART1, 2, 3, SPI 1, 3, 4, 5, I2C3, CAN1, and many EXTIs using generated HAL library. USART 6 and SPI6 are not tested due to no chip in it. All are working fine with minor HAL code modifications.
It is strange to say HAL is terrible. I am confident that ST will enhance and improve HAL in the future. Also sw4stm32 will be integrated into Eclipse better and better. Currently sw4stm32 project under Eclipse has some broken problems when changing properties, but it can easily be fixed by modifying the .cproject/.project files.
I used to write code for PIC8/16/24/32, MSP430, MC16, SAM7, ARM9 chips by accessing registers directly. Now it seems STMCubeMX and HAL make my life much easier.
The wonderful thing is that STMCubeMX can help me to figure out much more peripherals to be used.
