Author Topic: DRC for eagle  (Read 4545 times)
Offline robotlyTopic starter
  • Country: kz
DRC for eagle
« on: November 22, 2016, 01:53:01 pm »
Hi, is there any suggestion for Eagle DRC? I did a single layer PCB with Eagle, before I send the file to PCB fab I want to know whether the 0 mil tolerance of the board Edge is ok?
Offline FreddyVictor
Re: DRC for eagle
« Reply #1 on: November 22, 2016, 03:30:50 pm »
who's the fabricator ?
they often have a DRC file on their website you can download to check your board against
  • Country: kz
Re: DRC for eagle
« Reply #2 on: November 23, 2016, 03:07:57 am »
oh yes, there are manufacturing DRC file on their website, but it is too humble in their website
Offline Josephine85
Re: DRC for eagle
« Reply #3 on: November 25, 2016, 12:34:54 pm »
Hey Hey,
thers a lot of stuff about DRC on the CadSoft EAGLE Blog: https://cadsoft.io/blog/
Best regards,
Offline technotronix
    • PCB Assembly
Re: DRC for eagle
« Reply #4 on: December 30, 2016, 07:51:16 am »
As per the suggested by Josephine85, there are much more stuff provided at  https://cadsoft.io/blog/
Offline richardlawson1489
    • PCB Assembly
Re: DRC for eagle
« Reply #5 on: February 01, 2017, 07:48:20 am »
Here are some of the great suggestion on DRC for Eagle. https://www.element14.com/community/thread/4333/l/suggestions-for-drc-command
Offline ebastler
Re: DRC for eagle
« Reply #6 on: February 01, 2017, 10:21:49 am »
The discussion in this thread is about using the DRC, and how to set up the DRC parameters. I don't think anyone here wanted to develop the DRC implementation. And, last time I looked, Eagle was not open source anyway...
Offline westfw
Re: DRC for eagle
« Reply #7 on: February 23, 2017, 10:01:27 pm »
This tends to depend on the particular board fabricator (I'm not sure why.)   The eagle default is 40mils (HUGE!), and I try to avoid fine tracks near the edge (just cause I've USED router bits...), but I don't have any worries about letting the ground plane get within 10mil or so of the edge...
A long time ago, I wrote an instructable suggesting that most hobbyists should adjust the DRC parameters so that the resulting board is easier for hobbyists to build (and more robust, physically.)   https://www.instructables.com/id/Make-hobbyist-PCBs-with-professional-CAD-tools-by-/
