Hiya,
I'm not sure what Arduino library you are using but I have seen people with this issue previously when they used an Arduino library part that was intended for making shields, which basically gives you the board outline, connectors etc for you to then add components to, rather than using one which treats the Arduino as a component to be added to the board....
Best Regards,
Rachael
