Author Topic: EAGLE MEETS SKETCHUP - turn your Eagle layouts into 3D models  (Read 5095 times)
Offline paulcavTopic starter
Here is a method of creating a 3D model of your boards
https://eagleup.wordpress.com/installation-and-setup/
Offline GlowingGhoul
Re: EAGLE MEETS SKETCHUP - turn your Eagle layouts into 3D models
« Reply #1 on: March 06, 2017, 03:49:28 pm »
Can it create a 3D model of a perpetual license for Eagle?
Offline jgarc063
« Reply #2 on: March 06, 2017, 08:21:57 pm »
Hi GlowingGhoul,
This is actually a tool that existed well prior to the Autodesk acquisition so it does work with V7 of EAGLE.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Offline macegr
« Reply #3 on: March 06, 2017, 11:11:34 pm »
It can't create a 3D model of that but it could probably create a 3D-printable model that simulates the new license.
The following users thanked this post: GlowingGhoul
Offline Agent86
« Reply #4 on: March 07, 2017, 03:44:48 am »
ROFLcopter!!!  :-DD
« Reply #5 on: March 07, 2017, 04:11:48 am »
Only in fast-degrading plastic so it must be replaced every 30 days  :-DD
Offline technotronix
    • PCB Assembly
« Reply #6 on: March 07, 2017, 12:23:41 pm »
Will it work with Eagle 8 licensing?
Offline jgarc063
« Reply #7 on: March 07, 2017, 07:49:39 pm »
Hi technotronix,
It will, because the interface is based on a ULP and a Ruby plugin for Sketchup, not affected by any of the new changes.
Best Regards,
Jorge Garcia
Offline richardlawson1489
    • PCB Assembly
« Reply #8 on: March 08, 2017, 02:04:49 pm »
Thanks  jgarc063,
I will try it with my Eagle 8. Let see if it works ok.
