Author Topic: kicad 5 fp library wizard  (Read 1374 times)
Offline nikkoderic
  • Country: ph
  • We're all human, we're just like you man.
« on: October 03, 2018, 01:52:02 pm »
i can no longer find the library wizard. help.
Offline s8548a
  • Country: in
Re: kicad 5 fp library wizard
« Reply #1 on: October 03, 2018, 02:11:57 pm »
Can you please elaborate a bit?
What exactly you are trying to do? create a footprint? not able to browse them?
are you able to find your libraries in the footprint library table in Pcbnew Menu > Preferences > Manage Footprint Libraries
Offline donotdespisethesnake
  • Embedded stuff
« Reply #2 on: October 03, 2018, 04:56:20 pm »
The library wizard has been removed, since you can add libraries by other methods. Use "Browse libraries" to add libraries.
Bob
"All you said is just a bunch of opinions."
Offline nikkoderic
  • Country: ph
« Reply #3 on: October 04, 2018, 11:51:18 am »
How will i update my kicad github offline cache? And how will i add another github library, from digikey kicad atomic library for example? Im using windows version of kicad 5.
Sent from my SM-G925F using Tapatalk
  • Embedded stuff
« Reply #4 on: October 04, 2018, 02:35:39 pm »
1. Download the library/repo to your local disk. Unzip if necessary.
2. Go into "Preferences->Manage Footprint Libraries". Add any new libraries and delete any old ones.
Bob
Offline nikkoderic
  • Country: ph
« Reply #5 on: October 04, 2018, 11:52:12 pm »
no way to do this automatically inside kicad just by linking the github?
  • Embedded stuff
« Reply #6 on: October 05, 2018, 07:15:18 am »
I think you can add a github library by using "Append library" and then type values in the boxes, and it will work the same way as in v4. However, it will not download a local copy for use offline.
The Digikey does not have the right format to be used as a kiCad github source, you will need to download a local copy and then install the library.
Bob
Offline nikkoderic
  • Country: ph
« Reply #7 on: October 06, 2018, 01:44:47 am »
I think i get it now. Thank you :))
