Author Topic: KiCAD Access rights (5.0.0)  (Read 1463 times)
Offline CM800
« on: September 26, 2018, 01:40:58 am »
So, I've set up a lib of all my custom components in Google Drive.
Never used to have a problem, now suddenly I get issues with files being read only.
Not sure how i can stop this from being an issue.
It's doing my head in!
Offline donotdespisethesnake
  • Embedded stuff
Re: KiCAD Access rights (5.0.0)
« Reply #1 on: September 26, 2018, 06:12:08 am »
How exactly does this issue show itself? ie. what error message do you get.
Bob
"All you said is just a bunch of opinions."
Offline CM800
« Reply #2 on: September 26, 2018, 05:27:39 pm »
In the top bar of the software, the file name is given also with '(READ ONLY)'
and in attempt to save under the same name, it flat out says no.
I've also had a lot of crashes with the footprint creation tool.
Offline a59d1
« Reply #3 on: September 26, 2018, 06:00:08 pm »
Are you on Windows?
Offline CM800
« Reply #4 on: September 26, 2018, 06:41:10 pm »
Are you on Windows?
Can't believe I forgot to mention that.  |O
Sure am. :(
All my other files in the google drive are fine to open / edit (schematics, pcb etc.)
however, the footprint doesn't like working.
Create new library “${KICAD_GDRIVE}/KiCAD Libs/footprints/Phoenix Contact.pretty”?
Library “${KICAD_GDRIVE}/KiCAD Libs/footprints/Phoenix Contact.pretty” does not exist.
Would you like to create it?
Yes   No
Warning
Cannot create footprint library path “${KICAD_GDRIVE}\KiCAD Libs\footprints\Phoenix Contact.pretty”
OK
kicad Error
Directory '${KICAD_GDRIVE}\KiCAD Libs\footprints\Phoenix Contact.pretty' couldn't be created (error 3: the system cannot find the path specified.)
OK
the KICAD_GDRIVE has been set up correct AFAIK and seems to work in other places (including opening the files initiall)
Offline spudboy488
« Reply #5 on: September 26, 2018, 09:26:22 pm »
Turn Google Drive syncing off when working in KiCad. There might be a file contention issue where KiCad is modifying a file and Google is grabbing it to sync it.
Offline CM800
« Reply #6 on: October 16, 2018, 06:05:38 pm »
Yes, seems to be the case, cheers for the help. It's just weird as it previously was never an issue.
