Author Topic: Print footprint catalog  (Read 4712 times)
Offline AeternamTopic starter
  • Country: lu
    • Schartz Engineering
« on: September 25, 2016, 06:10:13 pm »
Hey guys,
Is there an easy way to print a catalog with all the default footprints in the Kicad libraries?
I'm asking because I'm having difficulties finding the correct footprints for my components. The idea is to compare the physical component to its printed footprint (scaled 1:1 of course), thereby confirming that it'll fit on the board.
Offline Watth
Re: Print footprint catalog
« Reply #1 on: September 26, 2016, 02:19:06 pm »
That's an interesting idea.
Having (most of) the footprints printed to scale can be a quick way to confirm its matchingness to components for which one might miss the datasheet, or more generaly for educative purpose.
Apart from doing it manually, I don't see KiCAD having such a feature, as it is sometime hard to have some more basic and common functionalities working.
So, if anyone feels like making a PDF or something...
Because "Matth" was already taken.
Offline technotronix
    • PCB Assembly
« Reply #2 on: September 28, 2016, 01:44:41 pm »
Yes, this is good idea. this link may help you. https://github.com/KiCad/kicad-library
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #3 on: September 28, 2016, 01:58:47 pm »
Another idea that will benefit you in the long run is to make all the footprints yourself. Yes. I mean all.
Though, I've got to say... A printed book sounds nice!
I've made this before: https://github.com/AlexanderBrevig/InventorsPad which programmatically made a PDF for Lulu and it should be easy enough to parse the library and make graphics from them.
EDIT: it would be the various .pretty/*.kicad_mod files you'd want though. For instance this: https://github.com/KiCad/Pin_Headers.pretty/blob/master/Pin_Header_Angled_1x03.kicad_mod
« Last Edit: September 28, 2016, 02:01:45 pm by alexanderbrevig »
Offline richardlawson1489
    • PCB Assembly
« Reply #4 on: December 30, 2016, 06:54:59 am »
Thanks, sounds good. I like the idea of alexanderbrevig.
Offline Deridex
  • IMHO
« Reply #5 on: February 18, 2017, 12:31:59 pm »
In the long term it's probaly the best to create your own librarys. Including Footprints and Symbols.
For hobby use i tend to use the librarys i found here:
http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm
Offline awallin
« Reply #6 on: February 18, 2017, 02:43:24 pm »
This script seems to parse footprints:
https://github.com/KiCad/kicad-library-utils/blob/master/pcb/kicad_mod.py
Next you'd need a graphics library that produces the output you want.
Perhaps cairo? http://www.tortall.net/mu/wiki/CairoTutorial
if you'd want to make it pretty there needs to be some smart nesting/ordering of footprints as well as pagination..
there are enough footprints in the standard libraries to make it not so much fun to do that by hand..
https://github.com/KiCad/kicad-library/wiki/Footprint-Libraries
  • Country: no
« Reply #7 on: February 18, 2017, 06:32:01 pm »
I would make use of a small lisp implementation and implement the calls for graphics. The real question; would anyone buy it?
