Author Topic: KiCad 5.0.0-rc3 Released  (Read 5647 times)
Offline s8548aTopic starter
  • Country: in
« on: July 03, 2018, 05:16:21 am »
Offline Warhawk
    • Personal resume
Re: KiCad 5.0.0-rc3 Released
« Reply #1 on: July 05, 2018, 11:06:55 am »
Hmm, RC3 sounds optimistic. I may give it a shot for a small board.
Has anybody already tried it?
Offline Bassman59
  • Yes, I do this for a living
« Reply #2 on: July 05, 2018, 05:27:08 pm »
Well, the RC was tagged yesterday. But, I've been using Kicad nightlies for a couple of years now, and I had a couple of boards built last month using whatever was the most-recent nightly at the time. The boards work as designed.
It's eminently usable.
Offline awallin
« Reply #3 on: July 05, 2018, 05:45:32 pm »
and what would be the top-3 or so features in 5.0 that would make me want to switch from 4.0.7 ?  :-\
Offline Warhawk
    • Personal resume
« Reply #4 on: July 05, 2018, 06:23:42 pm »
  • Vias Stitching
Offline Seph.b
« Reply #5 on: July 05, 2018, 11:37:22 pm »
Can the new version be installed along side the old v4 stable version?
Offline donotdespisethesnake
  • Embedded stuff
« Reply #6 on: July 06, 2018, 05:30:35 am »
Yes, with a little effort.
Bob
"All you said is just a bunch of opinions."
  • Country: in
« Reply #7 on: July 06, 2018, 06:11:42 am »
A few of them covered here:
https://forum.kicad.info/t/when-will-kicad-5-be-available/8563/13
Offline a59d1
« Reply #8 on: July 06, 2018, 06:17:15 am »
Offline awallin
« Reply #9 on: July 06, 2018, 06:19:20 am »
  • Vias Stitching
Woohoo!
excuse my ignorance and laziness but is there a video or image-sequence somewhere of how wonderful via-stitching is in 5.0? thanks!
  • Country: in
« Reply #10 on: July 06, 2018, 06:46:39 am »
New features in V5 footprints like arbitrary shaped pads and rounded rectangle pads were not backward compatible.
and it has covered in detail here:
https://forum.kicad.info/t/does-v5-have-to-overwrite-on-install/11282
Offline bson
« Reply #11 on: July 06, 2018, 04:17:03 pm »
Nope.  The version isn't part of the library path and the v5 library can't be used with v4.
Also, your project will need to be converted, but that's easily managed with git or whatever in case you need to roll back.
  • Embedded stuff
« Reply #12 on: July 06, 2018, 06:11:29 pm »
I wrote up the procedure for installing v5 with v4 on Windows here https://github.com/bobc/kicad-doc/wiki/Installing-KiCad-v4-and-v5-side-by-side I'm sure that the same thing can be achieved on most Unix systems, if not MacOS.
I should add the caveat that once you save a project using v5, it becomes more or less difficult to go back and edit the same project in v4.
The default official libraries for the v5 release will be quite different to the v4 libs, and you can't use the v5 libs in KiCad v4. However, you can use KiCad v5 with the v4 libraries.
Bob
Offline Bassman59
« Reply #13 on: July 06, 2018, 10:40:40 pm »
You won't want to go back to the 4.0. The new stuff is really a lot better.
Offline bson
« Reply #14 on: July 09, 2018, 05:11:16 pm »
I really like that I can just drop a component onto a wire have it automatically connect it and trim the wire.  Also, the automatic connection management was long overdue.  And schematic wire management is greatly improved; you no longer get a ton of little segments, with potential connection (wires and pins one iota apart) issues, and they automatically recombine into single wires.  This is basic functionality that you don't think of that mostly just works and when it doesn't it's just a pain in the rear.  In v5 it's been a long time for me since ERC came up with anything disconnected, well, that wasn't an actual omission.
« Last Edit: July 09, 2018, 05:12:57 pm by bson »
