Author Topic: Is thera way to have a bus availiable across sheets?  (Read 2576 times)
Offline Dan MoosTopic starter
« on: August 06, 2017, 07:51:44 pm »
I have a 16 bit address bus I want to be on multiple sheets. do I have to send each wire of the bus to each sheet, or is there a way ton just label the bus?
Offline hermit
Re: Is thera way to have a bus availiable across sheets?
« Reply #1 on: August 06, 2017, 10:58:55 pm »
I've haven't used the bus feature yet.  Did you see if it would accept a label?  If you don't get an answer soon I can ask on the KiCAD forum for you.
Offline donotdespisethesnake
  • Embedded stuff
« Reply #2 on: August 07, 2017, 09:55:37 am »
Are you looking for a global bus? I don't think there is that feature, but you can route a bus through hierarchical sheets.
https://forum.kicad.info/ is a pretty active forum, you should try it!
Bob
"All you said is just a bunch of opinions."
