Author Topic: Simple stuff samples for Kicad.  (Read 3188 times)
Offline CHexclaimTopic starter
  • Country: uy
« on: June 04, 2018, 09:11:50 pm »
Hello!
I need to make a pcb with two linear power supplies, 78xx type. I never used a PCB design tool. I've install Kicad. I understand it has a steep learning curve at the begining, as any other cad tool.
As what I need is very simple, I thought I would find online varios examples that I could load into kicad, modify size and shape and minor things and have it done quick enough while at the same time learn how to use the tool.
I found some examples but of really complex boards. I could not find simple thing like power supplies, through-hole stuff, etc.
Does anybody know of a source of these ?
Thanks.
Offline janoc
Online Doctorandus_P
Re: Simple stuff samples for Kicad.
« Reply #2 on: June 21, 2018, 01:39:29 am »
When new to KiCad your first task will be to get acquainted to the user interface.
I found the "Getting started with KiCad" pdf a very good entry point.
With it I was guided through the whole workflow and designed my first (very symplistic) PCB in a single afternoon.
http://kicad-pcb.org/help/documentation/#_getting_started
  • Country: uy
« Reply #3 on: June 21, 2018, 02:49:52 am »
Thank you!!
