Electronics => PCB/EDA/CAD => KiCad => Topic started by: Floopy on October 15, 2018, 05:33:01 pm
I recently upgraded to KiCad version 5. So far it's been okay but every time I try to assign a footprint to a component, it just freezes up and about 30 seconds later it just pulls up a blank list. I've tried uninstalling it and reinstalling it with not luck. I can't find anybody else mentioning this problem. What's happening? I have a project that I need to finish soon.
:scared:
do you have (good) internet connectivity with ports and IPs/firewalls allowing git-access to github?
it may try to update from github every time you start the assigning-tool from schematic-editor.
the workaround may be to download libraries to local files and point your library table there instead of github.
I downloaded the libraries and deleted the github.xxx ones. It seems to be working now? I have a very fast internet connection, I have about 40mbps.
Well it works, that's the essential. Thanks! :-+
I am pretty sure I've seen that bug and it has already been reported; the footprint "filter by number of pins" seems broken and hangs the app for several seconds. Fortunately it's usually possible to use the filter-by-name feature (which still works).
https://bugs.launchpad.net/kicad/+bug/1801622
They are claiming it's fixed in the nightly build (see link)
Probably similar to that: https://www.eevblog.com/forum/kicad/footprint-association-tool/ (https://www.eevblog.com/forum/kicad/footprint-association-tool/)
Removing the 'fp-lib-table' file usually does the trick. It's in the user's config. directory (on Windows, it's 'C:\Users\XXX\AppData\Roaming\kicad').
That was an amazingly good tip, it's fixed!
Bravo.
