Author Topic: KiCAD footprints and 3d models  (Read 3914 times)
Offline VEGETATopic starter
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« on: November 05, 2018, 10:28:18 pm »
Dear friends,
I have a design with through hole components, but I am confused about which footprints to use for resistors, ceramic caps, and elec. caps.
There is the 5mm between each leg and there is more or less. I want to ask which one do you use?
Also, I have a DC jack on board but I didn't find a suitable 3d model for it. I used the footprint in library but there is no 3d model for it.
I will keep you updated if I have another problem of other footprints.
thanks!
Offline Bassman59
  • Yes, I do this for a living
Re: KiCAD footprints and 3d models
« Reply #1 on: November 06, 2018, 01:24:14 am »
I thought that most of the footprints in the official Kicad libraries had 3D models. I could be wrong.
So, since there are about 8 million or so different flavors of DC jack, it's helpful if you tell us which specific jack you are using. And you can check that jack's manufacturer web site, as many vendors now publish 3D models of their parts.
  • Country: jo
    • Thundertronics
« Reply #2 on: November 06, 2018, 05:06:12 pm »
This is my board until now, it is complete but without routing. See the jack at top left there, I have a general Chinese one, no name brand.
Offline james_s
« Reply #3 on: November 06, 2018, 05:46:54 pm »
I don't bother with the 3D models. I played around with them in the early days but quickly found it to be a waste of time. If I can't find a good match for the part I want right off I just create it myself off the datasheet, perfect result almost every time.
Offline hermit
« Reply #4 on: November 09, 2018, 04:06:45 pm »
I think some of the old libraries had 3D model but it didn't make it to the new version.  You can check there if it is really that important to you and you have the time to burn I guess.
Offline G0MJW
  • Mike
    • G0MJW
« Reply #5 on: November 10, 2018, 10:37:25 pm »
I had the same problem. In the end I downloaded a CAD model from a CAD website. These are very common and there was one in the older version so it is surprising someone thought it a good idea to delete it. Presumably because it wasn't up to scratch but to leave users with nothing is not really all that helpful either.
Mike
Mike
  • Country: jo
    • Thundertronics
« Reply #6 on: November 11, 2018, 07:04:39 am »
Mike
This looks great, please share the link if possible.
  • Country: jo
    • Thundertronics
« Reply #7 on: November 12, 2018, 10:16:22 am »
I found also that ceramic capacitors footprints differ. I need 100pF but it is only available in 5mm lead spacing package from lcsc, thus I would need to adjust it. Which will result in adjusting other ceramic caps such as 10nF and 100nF.
I thought of leaving the footprint at 2.54mm as it is then bend the leads a bit, but I thought it would be ugly. What do you guys think?
