Author Topic: Newbie Help  (Read 3394 times)
Offline Ranger14Topic starter
Newbie Help
« on: January 25, 2017, 03:06:57 am »
I am running kicad on Linux Mate 18 (Sarah) but are having some problems.. My parts list is very short and doesn't include  normal resistor,smd parts,and others??
So what am I missing and is there anything else I should know ?? Also how hard is it to create a negative of the pcb for Negative type photoresist??
Thanks
Offline james_s
Re: Newbie Help
« Reply #1 on: January 25, 2017, 03:31:35 am »
Did you add the libraries with the parts you want to your design? Are we talking the schematic symbols or the PCB modules?
I've never tried to print a negative image with it so I can't help you there. Surely it's possible somehow though.
Re: Newbie Help
« Reply #2 on: January 25, 2017, 03:43:32 am »
I am talking  about normal sch parts ..
I added the library's off the Software manager and am I missing something ??
Offline james_s
Re: Newbie Help
« Reply #3 on: January 25, 2017, 05:48:35 am »
When you have your schematic open, go up to Preferences> Library and add the libraries you want to use, then the parts they contain will be available to put into your schematic.
Offline bitwelder
Re: Newbie Help
« Reply #4 on: January 25, 2017, 06:50:10 am »
Offline technotronix
    • PCB Assembly
Re: Newbie Help
« Reply #5 on: February 01, 2017, 12:15:29 pm »
As per the reference provided by the bitwelder, kicad-library package does not include everything in the GitHub repository, you have to add reference .lib manually
Offline richardlawson1489
    • PCB Assembly
Re: Newbie Help
« Reply #6 on: February 23, 2017, 07:33:05 am »
Which KiCAD version are you Running with?
Offline Deridex
  • IMHO
Re: Newbie Help
« Reply #7 on: February 23, 2017, 05:54:44 pm »
I suggest you get the complete Kicad-Lybraries from Github. Save em local on your working device and link to that folder.
That way you can work offline but still got a quite big startlibrary.
i think if you link to Github directly you could encounter problems when working offline.
