In addition to the original post, there are other needs to work on a group of parts, in particular adding and modifying fields for a group of symbols.
- In eeschema, managing fields can partly be done with "Edit Symbol Fields" but existing fields can neither be removed nor edited; e.g. errors can't be corrected.
- When visibility needs to grouply be toggled on or off: for example, footprints are appearing per default on the sheet. They are usually not desired and the visibility option needs to be toggled separately for each component.
- On top of that, working on a library would also be useful. Let assume that symbol pins are judged too long for the user's application. Reducing manually of 1.27mm all the pins of a bunch of symbols is an exhausting task. Automating the task is a real plus.
- Extending the question to footprints: Let assume that single sided PCBs are nominal for the production of simple boards. PTH are not needed, Reducing their dia is as painful as reducing pin length on symbols.
Until now, I did this for some componente but I quickly gave up for a complete board. As far as I know, there aren't any option nor plugin dealing with these specific needs.
Regards
