What is your current system? I've been using a 2mm cut out in the corner of my panels, with quite a lot of sucess. I have some mounts that have 'pins' that are 4mm in diameter, that match them. Its not *perfect* i do sometimes have to make minor adjustmetns for each print. I thought that was just normal. I include a 4mm octogon shape on the tool strip which is 100% the size of a copper ( also octogon ). and use those for the line up. Its a 'manual' fiducial i guess. The reason for the 100% apature there is that you want to be able to see the edge, or its possible to be slightly offset.
OK, what I am doing now is I have a plate with a grid of 10-32 holes on 1" spacing. (Sorry for imperial measurements, but that is what I use.)
I have adjustable bars that have a 0.062" step on one edge, so they hold the edge of the PCB, and can be tightened down to the plate.
Then, I take the frameless stencil and align it to the PCB, and tape it down with masking tape. The masking tape forms the hinge for the stencil.
I think a major cause of the rework issues I'm now having is due to imprecise paste alignment. So, I may have to make up something a lot more sophisticated for stencil alignment. So, maybe a method to put the stencil in an adjustable frame, and then adjust the alignment before printing. I was hoping to avoid that. And, for the low-density stuff with 0805 passives and SOIC, that all works fine. But, when I have SSOP and 0.5mm FPGAs, it just isn't good enough.
Thanks,
Jon
