if the claim that only 10% are getting better than 90% FPY is correctly, then getting 99.9% is amazing. its 100x better. I know that I'm getting better rates than my old contract manufactuers did. Maybe becuase i actually care about my work, maybe because i am doing a better job of optimizing my designs for our line.
Maybe because for the main, i can get solder paste on the boards relaibly!
I'd like to get higher than 98%. But Polishing costs money. I'm often doing projects in teh order of 100-500 units. Two approaches.. If i was making 500,id expect 10 to have an issue. I could just overmake units.. and not bother to fix the broken ones. This sounds wasteful, but it might be the best way. ( an increase of 2% costs of materials ). Or i could take the hit and fix thm. Either way, its possiby cheaper than spending a week or more time to make the required changes, to optimize things better. On a job when your going to make 10,000,000 then it certainly makes sense.
There are things i've done that have made great improvements.
- I moved to using GC10 paste. For small runs its so easy to use, its a big time saver
- I upgraded stencil printer. That made a big improvement.
- I dont' let the Stencil manufacturer do stencil reductions... Its all calcualted.
I agree with you, the use of QFN's over QFPs' are a great thing.
I'm not in this game to get 99.9% rates. I'm in it to optimize profits. I'm trying to figure out where teh right target should be.
