Hi all,
I have tried milling a PCB (smallest track/space around 0.2mm) with 0.2mm, V shape, 30 degree bit but results are extremely poor. The copper seem to melt (even if I setup coolant during milling), edges are rough and finer tracks are narrower than the design. I have tried this with different feed rates, different depths, different bits, but results are same.
Then I switched to 0.1mm, 10 degree, V shaped bits and results are amazing in the first run it self. Only issue with this is they break easily. On top of that I have run out of such bits now and will have to wait for 3 weeks to get new ones from aliexpress. (This is not available locally). But I seriously want to finish a PCB which I started to work on soon.
My question is, does any one here had any luck using 0.2mm, 30degree, V shape bits to mill a pcb which has 0.2mm tracks nicely? I am talking about the quality similar to what you see in all wegster CNC channel in you tube. With 0.1mm, 10 degree V shape bits, the quality was similar.
Cheers
