Well, that's only half the story. You will buy some cheaper (or in my case, locally sourced) filaments, and you're again fiddling around with some values. That's not quick/easy!
So your argument against the Prusas is that you wouldn't buy good filament if you bought a Prusa. What.
So there are definitly good alternatives for the i3... the Lulzbot ones are also open-source as the Prusa ones!
maybe it was just the i3 Mk3 launch making people just blindly running after these...
I never said there weren't. I just happen to be somewhat familiar with the Prusa machines. .. and no, I'm not some fanboy with a garage full of them. I own 0.
No, I mend all that easiness is going away if you use filament other than the "supported".
From my experience, +-5° Extruder-Temp, +-5% Filament Diameter, +-20mm/s Print Speed matters a lot!
And the filament is only 1 part of the equation.
e.g. If I've a Print where I have long straight lines to print, I tend to go a little hotter.
For Prints with loads of small sections I increase the fan speed... which is the #1 noise source... so I tend to slow it down as much as i can.
In the end, I get really nice prints, but I would not call 100% first time right. Which matches the observations of ar__systems...
73
