Yeah, we have used Dupont Riston off Ebay successfully. But we happened to have two big rolls from the industry from the early 90's, which should be badly out of date, but it still worked perfectly so we have been using that free stuff without any issues.
You can wet laminate it with a squeegee (spray a little bit of water - stick it to the clad - squeegee all the water out - oven at 80 degC for a few minutes IIRC), and we started with that, but then we rearranged our process so that we CNC drill first, and wet lamination stopped working due to the holes. (Drilling first makes alignment easy, and allows you to compensate printing the mask to actually fit holes, instead of destroying the complete board you have worked with for an hour by accidentally drilling it with an offset.)
In the industry, the dry film is laminated using heat and pressure - it's basically a big-ass heavy-duty office laminator!
Which got us thinking, maybe a standard super-cheapo office laminator (meant for laminating paper in plastic pouches) would work.
And yes, it worked perfectly! This is easier than wet lamination, as well.
Biggest PCBs we do are A4 size (around 210x290 mm).
We built the point source UV unit just using random Ebay UV LEDs... No issue there. Sometimes the Ebay LEDs are crap, though, so we were lucky.
IIRC, 380nm would be the optimal wavelength for dry film materials, but 405 nm works well enough (requires maybe 3-4 times more power), but 405nm is at least ten times cheaper per watt so that you obviously want to use that.
