Author Topic: Cheap high voltage insulation tester  (Read 1608 times)
Offline ocsetTopic starter
« on: November 22, 2017, 03:38:16 pm »
Hello,
We need an end-of-line tester for our offline led lamps production line. (40 to 150W)
All it does is take the impedance between Mains Live/Neutral and Earth.
-And yet it costs £6000.
Why are they so expensive?
Do you know of a cheaper one?
Our production staff are having to share one and they are almost having fights with each other over it.
We desperately need another one.
Do you know of a cheap one?
 :scared:
Offline Mattylad
Re: Cheap high voltage insulation tester
« Reply #1 on: November 22, 2017, 06:22:24 pm »
We have the same fights in production, other departments keep stealing our tester because they broke theirs.
We have a Fluke 1662 type, far cheaper than what your saying. BY high voltage, how high are you wanting?
Matty
CID+
The following users thanked this post: ocset
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: November 22, 2017, 06:29:19 pm »
Without knowing anything else about your scenario, if you need to simply measure insulation would a basic UT513A work? It is a decent insulation meter (I have a UT513 non-A) in the range of a Fluke 1550C - it probably is not as sturdy as the Fluke but it gets the job done.
Offline Nauris
« Reply #3 on: November 22, 2017, 08:05:47 pm »
GW Instek GPT-9803 is only 1950€ (+VAT)
Offline DerekG
  • Country: nf
« Reply #4 on: November 23, 2017, 12:39:21 am »
Can you use a megger tester? If so, there are many models that let you select the testing voltage.
They vary in price from very cheap to reasonable.
I also sat between Elvis & Bigfoot on the UFO.
Offline 3roomlab
« Reply #5 on: November 23, 2017, 02:12:23 am »
i have a UT512, i find it to be highly inaccurate. i ended up putting the HV thru a uA meter to get an idea of the "insulation leak". does anybody else also use it in this way like me?
