Author Topic: Cheap prototyping solder paste stencils for QFP 100 - where?  (Read 5142 times)
Offline DTJTopic starter
« on: April 28, 2016, 11:44:24 am »
Are there cheap solder paste stencils for something like a  0.5mm pitch QFP-100?
eBay seems to have lots of really super cheap BGA kits like these, 20+ for <Au$10:
http://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR8.TRC1.A0.H0.Xrework+stencil.TRS0&_nkw=rework+stencil&_sacat=0
...... but I can't seem to find similarly priced QFP-100 stencils
Alternatively has anyone come up with a nice method for laying down a bead of paste along the line of pads? Using a syringe I always seem to get too much or too little.
Offline Spikee
Re: Cheap prototyping solder paste stencils for QFP 100 - where?
« Reply #1 on: April 28, 2016, 11:48:08 am »
Design your own for 20$
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: April 28, 2016, 01:53:28 pm »
Use a pneumatic dispenser and the correct needle. I use 25g (red) for qfp.
Offline mazurov
« Reply #3 on: April 28, 2016, 06:32:07 pm »
OSH Stencils will cut you one from mylar for $5. You can also etch your own out of an old soda can.
With sufficient thrust, pigs fly just fine - RFC1925
Offline wraper
  • Country: lv
« Reply #4 on: April 28, 2016, 07:02:11 pm »
Mylar stencils for 0.5 mm pin pitch are basically useless. Also you cannot cut it from the soda can. 0.12 mm steel stencil is needed for such pin pitch to work well.
Offline IconicPCB
« Reply #5 on: April 29, 2016, 04:23:22 am »
I machine them in 0.2mm thick FR4 sheet.
Send me Your Gerber I will send You costing
Offline KE5FX
    • KE5FX.COM
« Reply #6 on: April 29, 2016, 08:04:14 am »
You don't need/want a stencil for QFPs.  Look for some YouTube videos on "drag soldering."
« Reply #7 on: April 29, 2016, 01:41:39 pm »
Use iron. With adequate technique and ample flux, a 0.8mm tip can do that in seconds.
Yep, that's the way I've always done it. It always looks rough, I thought it might be worth trying a stencil.
Thanks, you've given me a good idea, I might try cnc'ing one myself using some brass shim.
I've been laying the paste down using a manual syringe.
Offline IconicPCB
« Reply #8 on: April 29, 2016, 01:58:50 pm »
Wouldlike tohear of your efforts with brass shim.
Offline KL27x
« Reply #9 on: April 29, 2016, 10:03:10 pm »
+1. Stencil for QFN, sure. QFP, why? You will easily be able to put a 0.5mm QFP on with an iron before you can even finish pasting the stencil. Doesn't matter if it's a one-off or x 1000.
When there's hundreds of components on one stencil and a PnP machine, ok, now you're talking.
Having no PnP, if I use stencil, I go out of my way to remove IC's like QFP, unless they're in an awkward location. As long as there is access, it's easier to put them on after the rest of the reflow. Less reworking/inspection. Also saves some cost on relatively expensive IC's,  if you end up with excess boards and don't use them all.
My personal magic is a 3mm CF tip. Not only works for drag soldering, it is a great all around tip for SMD work.
« Last Edit: April 29, 2016, 10:11:10 pm by KL27x »
« Reply #10 on: April 30, 2016, 01:05:26 pm »
Would like to hear of your efforts with brass shim.
I'll make an effort to try it out.
Offline KL27x
« Reply #11 on: April 30, 2016, 06:19:03 pm »
My personal magic is the free bundled tip from my WES51.
I used w/e tip came with my iron for the first 6-7 years in the hobby, now somewhat of a business. I can solder just about anything with a hot stick, no problem.
But in hindsight, I wish I had not been so McGuyver all those years. They make different soldering iron tips for a reason!
