I'm trying to find a good PCB manufacturer in China. My previous one (
http://www.kbt.net.cn/) was cheap but produced warped boards as well as 50% of the boards has loose TQFP leads. Bad boards were then not successfully repaired. I found a new supplier (
http://www.Hampoo.com) but they are only a middle-man, has quite high prices and requires high volume. Otherwise they are good.
Can anyone recommend one/some of the Chinese manufacturers on the EEVBlog list?
http://www.eevblog.com/wiki/index.php?title=PCB_Manufacturers#ChinaIdeally, they will be able to handle complex boards (type, 10 layers, blind vias) but also be able to produce prototype boards. Quality is more important than price (but I don't want to throw money away).
Please only respond if you have *actual good experience* with a particular factory. I know how to Google but it is impossible to find which ones are any good.
Thanks!
/John
