Electronics => Manufacturing & Assembly => Topic started by: dino on March 03, 2018, 08:06:22 pm
Hi all,
I'm making an enclosure cover from FR4 with black soldermask, and it would be great if I could mount it using countersunk screws.
Does anybody know a PCB manufacturer that can make a PCB with ~2.6mm countersunk holes? (for M2.3 screws)
Preferably in Shenzhen.
Dino.
Poshalji mi gerber/dxf.
Ja proizvodim shtampu u prototipnoj izradnji.
Proces proizvodnje se zasniva na mehanichkoj obradi bakra.
Zenkvane rupe nisu problem.
Eurocircuits can do this. (https://www.eurocircuits.com/chamfered-mechanical-holes-or-countersunk-holes/)
Some manufacturers can do in Shenzhen! :)
Dino.
Hvala na ponudi, treba mi veca kolicina, ENIG + mat crn soldermask, i osetljiv sam na cenu, pretpostavljam da ti to nije interesantno.
So far I found PCBWay in Shenzhen, if you insert countersunk holes, price is raised by more than two times at >100pcs.
My guess is that Eurocircuits is similar.
Pozlatu ne radimo.
Nudimo samo srebro.
Razlog je kojekakva opasna i zakonom regulisana hemija koja se koristi u prpizvodnji pozlate.
Svi smo osetljivi na cenu i mi koji pokushavamo da se hvatamo u koshtac sa kineskim cenama znamo koliko shta koshta.
A ti ako hocesh poshalji informaciju i mi cemo ti odgovoriti sa ponudom.
Mogu da t ikazhem da imash relativno dobrog proizvodjacha EIPCB u Nishu a isto tako i jednu manju radionicu to negde u Novom Sadu cini mi se.
Ako je tvoj zahtev relativno jednostavan i u pitanju je samo oblik i vrsta rupe to nebi trebalo da predstavlja neki narochit problem u proizvodnji,
Manufacturing seeks places with cheap labor cost and weak currency.
Soon enough China will price itself out of the game and some other country ( Vietnam for example ) will be the new what ever.
If the cost increase is too great from the board shop, you could extend out the solder mask a little more & countersink the 2 holes yourself on the drill press. Once you set the drill press stop, it would take you less than 20 seconds tops. A black screw head would be nice :)
I don't think that price increase would scale as much, however Eurocircuits is many times more expensive to begin with.
