Author Topic: Countersunk holes on PCB  (Read 3495 times)
Offline dinoTopic starter
  • Country: cs
    • Hackaday profile
« on: March 03, 2018, 08:06:22 pm »
Hi all,
I'm making an enclosure cover from FR4 with black soldermask, and it would be great if I could mount it using countersunk screws.
Does anybody know a PCB manufacturer that can make a PCB with ~2.6mm countersunk holes? (for M2.3 screws)
Preferably in Shenzhen.
Offline IconicPCB
Re: Countersunk holes on PCB
« Reply #1 on: March 05, 2018, 06:37:58 am »
Dino.
Poshalji mi gerber/dxf.
Ja proizvodim shtampu u prototipnoj izradnji.
Proces proizvodnje se zasniva na mehanichkoj obradi bakra.
Zenkvane rupe nisu problem.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: March 05, 2018, 07:34:00 am »
Offline noras
  • Country: tw
    • PCB star page
« Reply #3 on: March 05, 2018, 07:48:24 am »
Some manufacturers can do in Shenzhen! :)
  • Country: cs
    • Hackaday profile
« Reply #4 on: March 08, 2018, 09:05:38 pm »
Dino.
Hvala na ponudi, treba mi veca kolicina, ENIG + mat crn soldermask, i osetljiv sam na cenu, pretpostavljam da ti to nije interesantno.
Eurocircuits can do this.
So far I found PCBWay in Shenzhen, if you insert countersunk holes, price is raised by more than two times at >100pcs.
My guess is that Eurocircuits is similar.
Offline IconicPCB
« Reply #5 on: March 08, 2018, 09:25:52 pm »
Pozlatu ne radimo.
Nudimo samo srebro.
Razlog je kojekakva opasna i zakonom regulisana hemija koja se koristi u prpizvodnji pozlate.
Svi smo osetljivi na cenu i mi koji pokushavamo da se hvatamo u koshtac sa kineskim cenama znamo koliko shta koshta.
A ti ako hocesh poshalji informaciju i mi cemo ti odgovoriti sa ponudom.
Mogu da t ikazhem da imash relativno dobrog proizvodjacha  EIPCB u Nishu a isto tako i jednu manju radionicu to negde u Novom Sadu cini mi se.
Ako je tvoj zahtev relativno jednostavan i u pitanju je samo oblik i vrsta rupe to nebi trebalo da predstavlja neki narochit problem u proizvodnji,
Manufacturing seeks places with cheap labor cost and weak currency.
Soon enough China will price itself out of the game  and some other country ( Vietnam for example ) will be the new what ever.
Offline DerekG
  • Country: nf
« Reply #6 on: March 09, 2018, 01:19:28 am »
If the cost increase is too great from the board shop, you could extend out the solder mask a little more & countersink the 2 holes yourself on the drill press. Once you set the drill press stop, it would take you less than 20 seconds tops. A black screw head would be nice :)
I also sat between Elvis & Bigfoot on the UFO.
Offline wraper
  • Country: lv
« Reply #7 on: March 09, 2018, 01:50:58 am »
I don't think that price increase would scale as much, however Eurocircuits is many times more expensive to begin with.
