I just get a block of timber, put my boards on it, put some nails in the mounting holes and tap them in. Put the stack in the circular saw and cut. Just gotta make sure there is enough space between boards on the "panel" to account for the kerf. The saw is a pretty decent one, can use many types of blades, has adjustable speed (for tiles/masonry, wood, abrasive steel and cold cut steel), it also came with a mount for a couple of dispensing tubes, for water, air or oil. I use an abrasive wheel with the water dispenser.
