Hi all,
as the topic already says: Anyone here with a BRTRO-420 reflow oven who could share his/her opinion on that machine? Search only turned up the same question half a year ago, but maybe in the meanwhile someone has bought one?
My reason to ask: I am looking into buying a small reflow oven in the 500$ price range. I am only doing a handful of boards now and then, and right now I am using a modified hot plate, which works reasonably well, but lacks proper exhaust, one needs to press larger boards down, no proper temperature curve so flux activation/wetting is sometimes not as good as it should be etc. I don't really want to outsource manufacturing right now, because due to the low numbers I figure that would be more time spent doing coordination and specification than it takes to do the boards myself.
The really cheap ovens seem to lack power/uniformity (T962), or are IR-only which seems to make things quite sensitive to board placement (e.g. the T962-C descriptions read like there might be a circulation fan, but I have also found one post saying that they would like to add circulation so I don't know).
The BRTRO-420 description (
https://www.aliexpress.com/item/Hot-air-Infrared-2500w-Mini-Reflow-Oven-BRTRO-420-300-300mm-BGA-SMD-SMT-Rework-Sation/32747834351.html) clearly states a circulation fan, which hopefully should make the temperature distribution more even. The unit looks decent and would have just the right size for my needs (max boards 20x10xm). But any info from a real owner of the machine would be much appreciated!
Best,
Tassilo
